HX35 - 21cm2 to 12cm2 wastegated housing
Postby Brutus_Marcus » Mon May 19, 2008 10:11 pm
Hi,
Am wondering if its possible to change the exhaust housing from 21cm2 to 12cm2 wastegated housing (from the 210Hp motor)on the Holset. I basically need a little more low end and dont plan to touch the pump settings as of now. Buying a new Turbo off the block would be pretty expensive and i really dont want to spent that much.
What all would i have to change, if its even possible?
And do i have to change the impeller too?
Sorry for all the Newbee questions....
Regards,
Bikram
Brutus_Marcus
Postby Philip » Tue May 20, 2008 4:36 am
The housings will interchange as far as the turbo is concerned. No wheel changes needed. Your exhaust system will need to be moved back around 1.25". If that isn't possible then the downpipe will need to be shortened that much.
Postby Brutus_Marcus » Tue May 20, 2008 1:35 pm
Thanks a lot..
Dont have to worry about moving it further backwards as the motors in a 62 nissan patrol.
Brutus_Marcus
Postby GO OVRIT » Tue May 20, 2008 2:10 pm
You sure don't see too many of those around. Is it a 4bt or a 6bt Cummins?
GO OVRIT
Postby Brutus_Marcus » Tue May 20, 2008 11:33 pm
Its a 6BT, hav'nt bombed it coz am still using the stock 4 speeder and axles. Got diff-locks and 33 Boggers, and nothings broken till now.
Brutus_Marcus
