how do you tell if youve ran too hot
Postby randyswelding » Wed Jun 25, 2008 4:30 pm
ok so after the injecters she has stumbles like a misfire after i run her hard egts around 1350 to 1450 just for a few seconds then i let it get down while at a stop sign or light and itl stumble drive it nice and easy not seein over 1200 egt and it wont stumble and it sound diffrent under the hood.i did notice today with the hood up it shakes more,until i let the hood down a little(bout 1/2 way)did i hert my motor? or what in the heck is goin on i still have the stock turbo on her as of now until i can save some pennys up. thanks for any help
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby PToombs » Wed Jun 25, 2008 5:31 pm
Maybe put a fuel pressure guage on it and go for a ride. You might be starving for fuel on the WOT run, then it takes a minute to catch up when you stop.
Postby gear jammer 91" » Wed Jun 25, 2008 6:52 pm
That would be my guess too. I've seen 1500 briefly in two gears on my pyro and 1400 regularly, until diesel got so spendy now she's been detuned. :cry: Either way I've never had problem's like you are describing, but I'm still runnin stock sticks, so I wouldn't think it's the heat.
01 LB7
gear jammer 91"
Postby Cschafer » Wed Jun 25, 2008 7:36 pm
When your auto meter pyro comes back around to the "R" in pyrometer across the bottom you got it hot. 1500 for 15 sec is a good rule of thumb I hear. I've run 1650 for a about 14sec of my 15.30 runs with no problems.
91 w250 wrecker
Cschafer
Postby randyswelding » Thu Jun 26, 2008 10:19 am
thats what my farmin friend thinks too,where do i put it on the fuel line and how much psi do i need to see out of the gauge
randyswelding
Postby PToombs » Thu Jun 26, 2008 7:42 pm
Geno's Garage sells a banjo bolt for about $7 that's tapped for a 1/8th pipe fitting. Put it on the filter head on the line to the IP. Tie a gauge in there. You can drill and tap your own, but I don't recommend it. Those bolts are harder than the hubs of hell! :shock: I won't do it again, not for $7. ;)
Postby randyswelding » Fri Jun 27, 2008 3:41 pm
okdoky i was sitin in a parkin lot taday after work and runnin hard waitin for her to cool down and it was stumblin, turned her off then went in side for about 15 min. and back out ta start she fired right up and smoked white and stumbled :mad: until i got back on the road,then black :D so i ran nice and she hasnt done it yet,does that still sound like the lift pump?would goin to the 94 to 98 lift pump be better than the stock one and a gauge?
randyswelding
Postby PToombs » Fri Jun 27, 2008 6:18 pm
Lift pump or air leak. Need to get a guage in there so you can watch pressure. If it's air, pressure won't drop as much as starving for fuel.
Oh yeah! Piston pump is way better than the stocker. It's quite a bit more money too. :cry: Pump, line, spacer plate, 2 gaskets and new banjo washers are roughly $200.
Postby Begle1 » Fri Jun 27, 2008 9:19 pm
$200 is also the price you can get a used A1000, or A1000 clone for.
But that's not including the regulator...
Postby randyswelding » Sat Jun 28, 2008 11:58 am
i can see the posible air leak #4s injecter holder in nut is still leakin a little bit of fuel still i retightened it to 50ftlbs and my service manual(the big book) says 44ftlbs.what else should i try.im gettin the pistion pump conversion all the parts will be at cummins monday cant put it on til the 3 day weekend. :cry:
randyswelding
Postby randyswelding » Sat Jun 28, 2008 12:04 pm
oh ya and smoke level went down says all the country police :mad: thats bad when they stop ya and ask whats wrong!!
randyswelding
Postby canadiancrawler » Sat Jun 28, 2008 2:25 pm
If you are getting a leak at the retainer nut for your injector then it doesn't need to be tightened more,the injector needs a new brass washer.I had the same problem with mine until i changed the washer.
84 d350 srw crewcab CTD nv4500,soon to be pumped.sold
85 d350 drw crewcab 5spd 93 ctd bomb some.
93 w250 cc 5spd
canadiancrawler
Postby PToombs » Sat Jun 28, 2008 6:20 pm
RW, that's not an air leak, that's a compression leak. That won't affect how it runs, like the problems you're having. Like CC said, pull the injector, clean the bore and make sure the old washer comes out, then put in a new copper washer and torque it.
Postby randyswelding » Tue Jul 01, 2008 10:58 am
thanks guys did that and that one stoped then i think #2 bein pissi :mad: with me cause i got to do the same thing now to that one,i got the new piston pump but dont get the fuel line till wendsday,for a 4th of july swap party :D
randyswelding
Postby randyswelding » Tue Jul 01, 2008 10:59 am
thanks guys did that and that one stoped then i think #2 bein pissi :mad: with me cause i got to do the same thing now to that one,i got the new piston pump but dont get the fuel line till wendsday,for a forth of july swap party :D
randyswelding
