engine swap question
Postby mprmn08 » Tue Dec 30, 2008 4:11 pm
How hard or extensive is it to transplant a 1st gen cummins into a 95 chassis that used to be a gas motor. How much stuff will i have to change and or modify or live without to do it. I know i have to change the brake booster, right, to the hydra boost system off our trucks but what else would be involved? thanks for any input.
mprmn08
Postby KTA » Wed Dec 31, 2008 6:54 am
Is the 95 A 2WD OR 4WD, what do you plan to do about a transmission? How many more parts are you willing to gather for the swap? Was it a V10 or a V8 gas truck?
Postby mprmn08 » Wed Dec 31, 2008 4:25 pm
its a 4wd, auto, v8. well it depends. how many more parts do i need to gather. i mean i still have my 90 that the motor is coming out of to gather some parts off of. what other kind of stuff would i need. also will the auto out of the 95 gas bolt up to the cummins?
mprmn08
Postby Philip » Wed Dec 31, 2008 5:04 pm
The gasser trans will not work. It has to be a diesel trans.
You will need a diesel PCM and harness. Unhooking or leaving the engine harness unhooked will throw all sorts of error codes on the gasser PCM.
Postby mprmn08 » Wed Dec 31, 2008 5:17 pm
well ya. i plan on gettin rid of everything engine related with it. its a 1st gen cummins goin in so no pcm or bcm reguired for anything. now can those bell housings be switched or anything or do i need a whole new trans in order to keep it an auto?
mprmn08
Postby KTA » Wed Dec 31, 2008 6:36 pm
You will need a diffrent transmission, one from a diesel, and you will of course need the flywheel housing and flexplate to go with it. Keep in mind with no pcm none of the stock instrument cluster will work. It also wouldn't charge without the 89-90 voltage regulator setup being wired in/ added to the system.
