ksb solenoid
ksb solenoid
Postby boomer » Tue Jan 13, 2009 1:56 pm
I have a 1993 dodge 5.9 intercooled....club cab 2w.
My solenoid is leaking pretty heavy....and I'll be having the injection pump replaced soon due to internal failure.
How important is this solenoid...and....is the leak fixable? or does it usually require replacement when leaking?
My concern is that I've heard the solenoid costs 500 bucks....and I am hopeful that during the rebuild....I don't get a nother surprise expense...as the rebuild/reinstall is already costing 2400. OUCH
Thanks guys
John
boomer
Postby 1991cummins » Tue Jan 13, 2009 3:36 pm
to my understanding it advances the timing a bit for starting, i think this would be nice to have in cold whether... and it just depends where the leak is whether or not its fixable... i would carefully tinker with it to see if you can get anything accomplished... :)
1991cummins
Postby SChandler » Tue Jan 13, 2009 4:42 pm
Why is it costing you $2400 to get your pump rebuilt? :shock: You can buy a completely rebuilt one for $800-ish from places like this one: http://www.puredieselpower.com/catalog/90593-1st-gen-12v-cummins-stock-rebuilt-injection-pump-p-207.html.
My truck started leaking from the KSB and it was the tube going into the top of it. I replaced the tube and no more leaking. I think I posted the part numbers somewhere in this forum. I got the pieces from a local Bosch distributor/pump shop. It cost me $40 or so.
SChandler
Postby PToombs » Tue Jan 13, 2009 5:42 pm
And I'm pretty sure it's only an o-ring that seals the KSB to the case. I've yet to hear about a KSB going bad.
Postby MMeier » Wed Jan 14, 2009 6:19 pm
2400 for a rebiuld on a VE!!?? :shock: Is it going to be platinum plated or something??
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby Richie O » Wed Jan 14, 2009 6:24 pm
I think alot of shops are greedy. Most people do not have a clue ( including me ) how to seal the pumps. They just get into " the diesel stuff is expensive" mentality and screw people. :evil: I had a starter shop quote me 1200 for a starter for a excavator I have. Ended up finding one for less then half brand new. Same idea, " its a diesel, thats why its so much".
Postby dpuckett » Sat Jan 17, 2009 9:02 am
Isnt a NEW (never been installed on an engine) one around $1500 if you know where to look? I know PDR had them for $12-1300 a few years back, 205s even.
My local Bosch guy said a new one through him runs ~$2000.
Postby fasttalker83 » Sat Jan 17, 2009 6:08 pm
Dave give me a call 618-925-1262 and I can get you setup for nearly nothing I know could get er done for under 600.00--Im a Vendor for Area Diesel and Diesel injection Service's(Columbus Diesel same ppl) I rebuilt the one on my 90 for under 500.00 and that was putting new transfer pump cam plate rollers gaskets seals gov. spring etc. in it Plus Cape is only 70-80 miles from me
fasttalker83
Postby 77ctd » Sun Jan 25, 2009 9:05 pm
wow, 2400, one the main diesel tuner guys in my area happens to be a good family friend. And he charges $450 for a rebuilt VE and that includes labor in and out of your truck, sending the VE to the pump shop completely rebuilt and "supposed" slight tweek.
77ctd
