Oil Pressure Spike pls help
Postby IRoss » Tue Feb 10, 2009 9:18 am
What is happening here... :shock: the other day during a high boost romp my oil pressure pegged both gauges and then settled to 80 psi for the rest of my driving, about 1/2 to 3/4 throttle, fully warmed up and idling it rests at 50 psi...I cant imagine that excess oil pressure is a good thing fo the seals...should I even try to start it here in this cold weather...? What should I check ....thanks
91.5IC 4x4 5spd extra springs
valet, 190s, ,18cm, 4"ëxh.
H4 conversion w/relays
rwal mia w/prop. valve
IRoss
Postby mprmn08 » Tue Feb 10, 2009 11:37 am
do you have a mechanical gauge or electronic?
mprmn08
Postby IRoss » Tue Feb 10, 2009 6:58 pm
Aftermarket one is electrical, sender is on the filter mount..both gauges (this one and stocker) read higher that normal, though...I started t up this morning and it was the same, 80 psi cold and 50 psi hot...
IRoss
Postby mprmn08 » Tue Feb 10, 2009 7:28 pm
plugged filter?
mprmn08
Postby IRoss » Sat Feb 21, 2009 8:09 am
Well I changed the filter and cleaned out the pressure regulating piston over the oil cooler, made a big difference, ,but in my examinations I found metal shavings in the port below the regulating piston..I have'nt deided yet if I want to cut open the old filter and take a look, is this a common spot for filing deposits? :roll:
IRoss
Postby jogl » Sat Feb 21, 2009 3:40 pm
Triple check pressures with a known good gauge.
I hate to say it but: funky oil pressure plus metal shavings = not good.
If it were mine I wouldn't run it until I had checked main and rod bearings.
I hope I'm wrong!
Good Luck IRoss,
JP.
92 W250 and lots of others.
jogl
