Redneckintraining wrote:Do I need the return spring?
PToombs wrote:WOW! Look at that fuel inlet line! Mine comes along the back of the IP and makes a 90* bend straight to the inlet. That one makes a heck of a shortcut over the lever.
I had to adjust my fuel inlet line because the lever was hitting. (thanks Tim!) Then I realised that I still lacked about 1/4" from the stop. I had to add a couple washers to the cable at the pedal to get full travel.
I'm going to change my lever hole too, since I've seen posts on this.
sdstriper wrote:I wouldn't bend or heat anything etc. Get some washers and space the pedal out from the firewall a 1/2 inch or so.
