Engine stumbles when revved quickly
Postby cedardiesel » Wed Feb 25, 2009 8:04 pm
Well replaced lift pump and thought if might fix problem and still when revved if like misses in the low to mid range and once revved in to upper range it is ok. But at cruisin speeds it sounds like it is runnin off all injectors then it will sound like it is runnin off like 3 or 4 and also it feels like it has lost lots of power. Does this mean my injector pump gettin ready to say goodbye?
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby IowaCummins » Thu Mar 19, 2009 6:31 pm
bump your timing up. i just had the same problem you had and the timing was 1/16th" below the stock timing mark. i bumped it 1/8th" above the stock settign and now she revs when ever you want her to. and it makes starting when shes cold better and i picked up a few mpgs. sounds a little diffrent at idle but runs alot better
IowaCummins
Postby cedardiesel » Sun Mar 22, 2009 6:35 pm
Well thanks for the tip but done been sucked into the P-Pump hole and converting it over to that but I believe the pump is sucking air cause I bled the lines and all and it run good for bout 2 miles and it started the same problem again
cedardiesel
