need help!!throttle bushings
Postby randyswelding » Fri Mar 06, 2009 1:11 pm
i got a problem with my throttle cable where it conects with the rod to the pump,well the bushings in the spring linkage area are worn out and i cant find any one with some new ones is there a easier way to fix this?thanks guys i need this help fast the work truck is down
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby oldcool90 » Fri Mar 06, 2009 5:37 pm
You have a welder on the back of that truck right? :lol: :lol: :P :P
oldcool90
Postby PToombs » Fri Mar 06, 2009 7:02 pm
Don't listen to him, he hangs out with Bill. :roll:
I know it will suck, but can't you run it without until you can find bushings?
Maybe try PepBoys, NAPA, or Tractor Supply, they have bins of bolts, clips and stuff. They have brass bushings, maybe you can find some that are the right size.
Postby jogl » Sat Mar 07, 2009 4:58 am
X2 what Pete said. The good local auto supply places around here have selector boxes full of those sort of goodies. The trick is finding and good supplier with a counter person that knows more about looking for stuff than just banging on the computer.
Also, if you get real desperate you could go to the bone yard and try to find anything off of any vehicle that will get you going short term. A lot of that kind of stuff turns out to be standard sizes that were used in many applications.
Good Luck,
JP.
92 W250 and lots of others.
jogl
Postby sdstriper » Sat Mar 07, 2009 9:01 am
Are you talking about the Bellcrank bushings? The Throttle Shaft bushings? The little plastic ones? These are dirt cheap at Cummins man...
3914353 Bellcrank bushings qty - 2
3914354 Throttle Shaft bushing
sdstriper
Postby randyswelding » Sat Mar 07, 2009 1:49 pm
well this is what my dad got last night,brass tubin-didnt fit,a couple of bushings that fit the shaft but not the holes,and the lil red electrical bushings that are thicker on one side and those fit perfectly and i got a bunch left!when i had it apart i cleaned and painted the bracket and put some axle grease on the shaft that the big bushing for the spring is and put grease in where the throttle shaft goes and put it all together and it works perfectly now :D thanks guys for your input,the work truck(aka the mistress) is back on the road!!
randyswelding
Postby sdstriper » Sat Mar 07, 2009 3:36 pm
I'm gonna recommend a part book again...
Actual Cummins 6BT5.9 Chrysler 250/350 Pickups. Again, worth more than the cost. Sold by the year model.
sdstriper
Postby randyswelding » Sun Mar 08, 2009 12:43 pm
Where do you get one I already got a service manual and it didn't really talk bout it
randyswelding
Postby sdstriper » Mon Mar 09, 2009 2:07 pm
Cummins or ebay...
sdstriper
Postby sdstriper » Mon Mar 09, 2009 10:27 pm
After reading this again I think your talking about the plastic bushings in the throttle lever/breakover spring assembly. Search around for the VE pump parts breakdown it's probably here or over on the DTR. There's two pieces that your after if I am right...
You'll have to get them from a Bosch injection shop etc.
p/n 460522328
p/n 460522304
sdstriper
Postby Greenleaf » Tue Mar 10, 2009 9:09 am
Anyone know what items he really was talking about? It's tough when you don't know the item name. Imagine trying to get parts from Dodge. They often can't help you WITH the item number.
Greenleaf
tech specialist/mod
Postby sdstriper » Tue Mar 10, 2009 1:44 pm
Greenleaf wrote:Anyone know what items he really was talking about? It's tough when you don't know the item name. Imagine trying to get parts from Dodge. They often can't help you WITH the item number.
No kidding... 1st thing folks should do when they buy a vehicle is find all the FSM, Cummins part books and VE pump breakdowns.
sdstriper
Postby CAJUN 93 » Tue Mar 10, 2009 2:07 pm
welcome to a small part of a day in the life of a parts guy :D .
CAJUN 93
