boring motor
boring motor
Postby cumminz90 » Sun Apr 12, 2009 6:19 pm
hey everybody got a question about the blocks on these trucks i have a 1990 non intercooled motor that recentley blew a headgasket and when i pulled the head it also scoured up number 1 cylinder wall pretty good :cry: i was told the early 5.9 cummins was sraight bored and had no sleeves is this true? Also wondering about how much oversize pistons i can get a way with also at size piston should i go with im debating between 20 or 30 over any suggestions? :wrench:
1990 D250 sc Cummins: 175 p pumped motor: (400ccs)100 plate, 4k springs, rack plug,Jl machine 5x16 injectors, ad150, cooler tubz, hellman sump, studs, valvesprings, hx35/3b twins, timing 20 *, soon to be built 47rh
GFs: 1993 w250 cc: Normal pump mods, timing to the head, 3200 spring, denny t stage 2, DDP 4 injectors, hx 40, swapped in a rag
1991 w250 rclb: normals pump stuff 3200 spring
cumminz90
Postby mprmn08 » Sun Apr 12, 2009 6:52 pm
that is true. they are not sleeved. i would just go 20 over just incase something happens again, you can go 30 then
mprmn08
Postby PToombs » Mon Apr 13, 2009 7:39 am
You can only go .020 and .040. If the other bores are good you can just have #1 bored and sleeved back to stock. Then you only have to buy 1 piston and ring set too.
Postby cumminz90 » Mon Apr 13, 2009 10:15 am
ok thanks for the input yall :salut: i can get the pistons and rings a whole set shipped for 500 which are mahles which i thought was decent compared to 3300 dollars i got quoted for pistons rings and sleeves frum the cummins dealer has anybody heard anything bad about the mahle pistons or do they seem pretty decent?
cumminz90
Postby mprmn08 » Tue Apr 14, 2009 5:51 pm
malhe makes a very good piston. we use them all the time at work on motors. i've never used there cummins pistons but for various gas engines from street to very high performance and they make a good quality piston. they do expand a little more then like a JE or something so make sure you take your motor to a good machine shop that knows this to set the clearances right.
mprmn08
