What are my options? I trimmed mine,after it quit today. is their a replacement? a fix? where is the best price on a new one if not?
TOMMY
TOMTOM wrote:Well got tired of tearing up plunger tips so i decided to fix mine. as follows:
ground off all rubber with wire wheel, pressed on a regular 1/4 20 nut on the little nail-head looking tip. Then mounted it in drill turning it down on a belt sander . Got it to the same shape as the rubber tip.
Installed today and it WORKS. Will keep yall updated, have taken picks but they came out blurred.
TOMMY
p.s. Would i get more fuel without a plunger? It seems to tear the tip when i have run it hard not when the pump is turned to max like its a restriction.
PToombs wrote:I bet it's heavy enough that the solenoid can't pull it up. The lift pump helps push it open!
