Thanks for the info guys, a little too much info from Pete...
so here is the next question. I bottom tapped the holes, but i had to loosen the studs back up, becuase the nut would not go onto every thread if you didn't. Next, my mills at school are down due to a shorted circuit. I did not mill the tops of the rocker pedistals. If I do not use the washer under the nut it will clear the valve cover, if I do it hits. So is it ok to use the studs without the washers on the pedistals until my $900 breaker comes in? Then I will mill the vavlecovers to clear the nut and washer, it just touches the webbing.
Any thoughts.
Thanks,
Bob
In Progress: '84 Chevy Silverado dually w/19.5 rims.
1st gen, New Eras, s300, 366, DennyT, piston LP, Pacbrake, 60lbs. springs, ARP studs, Snow Perf. stage II, '97 DR IC, 4" stacks.
NV4500, 14 Bolt Locker & Dana 60 Posi w/3.73's
.200 deep by 1.1 wide as per arp instructions. i just got my new studs on thursday and am waiting for time to mill mine and resurface and fire ring the head.
