Ok for all you jokers out there that remove/pull injectors from the cylinder head with VICE GRIPS, this rant is for you! No more vice grips!! I'm tired of getting all set to install a new set of edm's or rebuilt injectors etc and then having to file down the burrs on the injector body because the previous joker pulled them with vice grips. This is the second set I've done that most or all of the bodies were chewed up and required a few minutes a piece with the file. So then you gotta spray them down ether or brake clean, then hit with air. I'm over it!
Build an injector puller for petes sake! Ten inch piece of all thread, proper metric nut welded to the all thread, some nuts, some washers and a hammer head or large socket are all thats needed for a cheap effective puller.
