How not to pull injectors
Postby bgilbert » Wed Jul 08, 2009 4:55 pm
Ok for all you jokers out there that remove/pull injectors from the cylinder head with VICE GRIPS, this rant is for you! No more vice grips!! I'm tired of getting all set to install a new set of edm's or rebuilt injectors etc and then having to file down the burrs on the injector body because the previous joker pulled them with vice grips. This is the second set I've done that most or all of the bodies were chewed up and required a few minutes a piece with the file. So then you gotta spray them down ether or brake clean, then hit with air. I'm over it!
Build an injector puller for petes sake! Ten inch piece of all thread, proper metric nut welded to the all thread, some nuts, some washers and a hammer head or large socket are all thats needed for a cheap effective puller.
Bill Gilbert
Postby PToombs » Wed Jul 08, 2009 5:37 pm
Don't build a puller for my sake, do it for Bill! :lol:
Bill, just clean them up with a 4" hand grinder. The next guy you sell them to will appreciate it.
Pay it forward! ;)
Postby Begle1 » Wed Jul 08, 2009 6:19 pm
Has anybody ever not been able to get injectors out just by cranking the engine?
I don't see why that isn't a more popular method.
Postby gear jammer 91" » Wed Jul 08, 2009 8:53 pm
If you set the hold down nut on the top of the injector, then put a deep well socket on it, you can hit the socket with a hammer and get the nut past the burs you (I) made when pulling them with vice grips. :lol:
01 LB7
gear jammer 91"
Postby SNOOT » Wed Jul 08, 2009 10:42 pm
I have never had a problem I give them a twist left and right and then pull straight out. Try a twist first works for me very time.
1993 W350
SNOOT
Postby BobS » Thu Jul 09, 2009 6:30 am
My method works and it's cheap to build:
http://www.4btswaps.com/forum/showthread.php?t=1773
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby mprmn08 » Thu Jul 09, 2009 4:49 pm
FWIW a 1/2 fine thread lug nut will screw on the injector threads to pull them. i know its not the right thread but it doesnt bugger them up or anything and it works good. trust me i did it.
mprmn08
Postby fergavs » Tue Jul 14, 2009 5:03 pm
You shouldnt twist the injectors in the bores. They have a "tit" for alignment and you could damage the injector or mark the head/bore. Try to avoid any twisting movement when pulling injectors. They should be lifted straight up and out.
fergavs
Postby PToombs » Tue Jul 14, 2009 5:54 pm
I was trying to pull one from a 4bt for my buddy. The nut was rusted to the body and I could not get it loose. He told me to just use the air wrench and get it out. :shock: OK, it's your head! I did, and now it it has a new really coarse threaded injector hole. ;) :lol:
I did get the new injector to go in, it didn't really damage the threads for the nut. It sure looked bad though! :lol:
Postby dpuckett » Tue Jul 14, 2009 6:17 pm
If you use 10" curved jaw Vice Grips, you dont touch the threads.
:lol: :lol:
DP
Postby PToombs » Wed Jul 15, 2009 6:22 pm
Bill, we know who did it! :lol:
