VE pump leak - primer rubber cap gone
Postby PapeCAT » Fri Aug 14, 2009 8:29 pm
So I have a leak off the back of my VE and I don't want to do a full reseal with the kit, but I guess I could , I have the reseal kit...
I just wanted to replace the seal that was leaking, but I couldn't Isolate the leak, one thing I did notice is that the rubber cap is missing off the rear of the pump , the primer button. Could it be leaking from there?
Thanks
PapeCAT
Postby PapeCAT » Fri Aug 14, 2009 11:03 pm
got the pump coming apart. WE'll see how this goes.... ve seal kit bleh... Just hoping if it all goes to you-know-what in a handbag I can at least limp it back together to use as a core and still have the privilege to pay 1000 dollars for a reman... :mad:
PapeCAT
Postby PapeCAT » Sat Aug 15, 2009 12:27 pm
Well that ,was not fun but I was able to replace the rear main o ring, front main seal, throttle shaft seal and pump top seal... Oh yeah and all the DV seals. That was all I really wanted to get into at this point. I'm crossing my fingers I got it all back together right and that I didn't FOD it out...
We'll see.
Progress continues on teh crew...
PapeCAT
Postby loco one » Sat Aug 15, 2009 5:05 pm
sounds good , you the man !
Locomotive one ,92,cc,le,4x4,nv4500,KDP,oldsmokee power pin, pac ,brake,14w/g,some pump tweeks,
loco one
