Low idle/dies when coming to a stop
Postby AlexT » Tue Aug 25, 2009 5:14 pm
I'm new to this site. Just recently bought a '91 intercooled 4x4 automatic. This is my first diesel and I love it. The truck is pretty high mileage (500,000) but is extremely clean and runs decent. There are a few bugs I need to work out though. One thing is when I'm slowing to a stop, the truck almost dies. The idle drops down REALLY low and falls on it's face. Any ideas ?
Also, when it warms up, the truck seems to be running one cylinder short.... I think I'm gonna pull out the injectors and have them pop tested. Any input you guys can provide would be great! I look forward to many hours spent on this website.
'91 I/C reg. cab 4x4
AlexT
Postby peobryant » Tue Aug 25, 2009 5:31 pm
How does it idle when it's warm? I'd try and bump the idle a little bit and see if it helps. It should be around 800RPM in neutral.
Postby AlexT » Tue Aug 25, 2009 5:34 pm
Very erratic when it's warm. Like it's down a cylinder. I'll have to take a look at the numbers and get back to you. Thanks
AlexT
Postby 12valve350 » Tue Aug 25, 2009 8:21 pm
my truck did the low idle thing too, and it was a overly dirty fuel fulter
Six in a row makes 'er go, Eight in a v, theres nothin' too see!
12valve350
Postby dpuckett » Wed Aug 26, 2009 8:18 am
Pop testing the injectors is a good place to start.
Postby Gunmetal » Tue Sep 01, 2009 3:19 pm
12valve350 wrote:my truck did the low idle thing too, and it was a overly dirty fuel fulter
I am also guessing fuel filter.
Gunmetal
Postby peobryant » Tue Sep 01, 2009 3:24 pm
Off topic, but Gunmetal, is the avatar picture your truck? If so, do you have a bigger picture of it? She looks good from what I can see. ;)
Postby Richie O » Tue Sep 01, 2009 5:30 pm
In my experience ( limited ) a dirty fuel filter effects top end performance not bottom end. I have had many times when my filter was gelled and the truck would idle fine but die with throttle. I also have had lift pumps fail in my 3406's and you lose top end first. How come nobody has mentioned that when the injection pumps get weak they drop rpm's at idle. ;)
Postby Gunmetal » Tue Sep 01, 2009 8:17 pm
peobryant wrote:Off topic, but Gunmetal, is the avatar picture your truck? If so, do you have a bigger picture of it? She looks good from what I can see. ;)
nosir, it is one I found on the internet that I liked so much I made an avatar out of it!
By your request!
I used the same image to make the header at 12valve.com
That's my site. I will have a review on the old smokey fuel pin up there for people to read, possibly a video if I feel energetic.
Gunmetal
Postby peobryant » Wed Sep 02, 2009 12:31 am
By your request!
Other than that chunk 'O fender missing, she looks real good. I kind of like the bumper painted the same color as the truck.
Thanks for the picture. 8)
Postby randyswelding » Thu Sep 24, 2009 6:03 pm
Well what if it idels fine when its above 145* but when lower it idels at like 200rpm?when its warm it sits at 700 so ill bump it up alittle but my pump only has 10k since the rebuild does that matter? Hopefully this will also help alexT
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
