Lets See Under Your Hood
Postby Dieselhick » Tue Sep 15, 2009 3:43 pm
I know most 1st gens aren't pretty under the hood but I want to see them anyways, please post pictures of your Cummins.
1991.5 D250, Auto, 2wd
Dieselhick
Postby Philip » Tue Sep 15, 2009 6:08 pm
First pic is air cleaner and turbo. The second is the other side of the engine. I don't have an overall view on the computer right now.
Postby Richie O » Tue Sep 15, 2009 6:31 pm
I could pick on you Philip ,,, but I won't. :D
Postby Ace » Tue Sep 15, 2009 7:09 pm
Ace
Postby Richie O » Tue Sep 15, 2009 7:21 pm
Postby Dieselhick » Tue Sep 15, 2009 7:32 pm
ACE, how is your fuel inlet on the IP set up, i see a push-on fitting, how did you adapt the push-on onto the factory inlet?
Dieselhick
Postby Ace » Tue Sep 15, 2009 7:50 pm
That's just a barbed fitting adapter to replace the stock fitting that comes in the Glacier Diesel Big Line Kit. It's a common Parker part# IIRC, if you just want that one piece.
Ace
Postby skilletky » Tue Sep 15, 2009 8:45 pm
skilletky
Postby gear jammer 91" » Tue Sep 15, 2009 9:13 pm
This shot is from a little ways away.
01 LB7
gear jammer 91"
Postby DieselSharker » Tue Sep 15, 2009 11:28 pm
She needs to be cleaned up a bit...I'll get to it when I get home.
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Postby pulltilbroke » Wed Sep 16, 2009 8:29 pm
Here are some of the configurations I've ran, the last pic is the most current
Postby TTipswprd » Wed Sep 16, 2009 8:33 pm
id like to know how hard it was to make that pipe for your hoodstack
TTipswprd
Postby pulltilbroke » Wed Sep 16, 2009 8:44 pm
took about 15 minutes to make, took a stock DP and whacked the flange off with a sawzall then I used the top 24" of a turn out stack flipped it upside down and then used the plasma to blow out a piece of 1/4 plate to adapt the DP flange to the stack and whala you have a hoodstack now you just gotta whack a hole in the hood :D
Postby TTipswprd » Wed Sep 16, 2009 8:48 pm
oh man thats what i like to hear! i am getting a dp for cost of shipping and i got two turn out stacks and some flex pip for free! guess im in luck. now to see how much the coppers like it!
TTipswprd
Postby pulltilbroke » Wed Sep 16, 2009 9:40 pm
They havn't bothered :D me when I was runnin it on the street
