HOT EGT,S AGAIN
HOT EGT,S AGAIN
Postby 1STGENFARMBOY » Tue Sep 29, 2009 9:04 pm
Im new on the site so be gentle, Im ok with the performance of my truck for now anyhow but the egt,s are hi, I think they would stop around 1600 but i let off the throtle at 1500 at about 75mph, would a 4in down pipe and 60cm upgrade bring them down. poor and out of ideas.
Postby Philip » Tue Sep 29, 2009 9:19 pm
You need more turbo and exhaust.
A 4" system will drop EGT's around 100 degrees. Thatis with a muffler or without.
A 60MM upgrade is only a stop gap measure. It might get you by for a while.
Postby peobryant » Tue Sep 29, 2009 10:38 pm
Like Philip said, a 4" exhaust and turbo are your best options. I also do not recommend the 60mm compressor upgrade for an H1C, because according to your sig. you have bigger injectors, and the comp. wheel upgrade will not cool as well as a bigger turbo. Get something with a 4" exhaust outlet, like an HX40 or S300.
You could also turn the pump down for a little while to help with the EGT's, but if the 1500* bursts are very short, you won't hurt anything.
Do you have a fuel pressure gauge?
Postby 1STGENFARMBOY » Wed Sep 30, 2009 5:21 am
i have it already mounted in the truck i just dont have it hooked up, i hate to cut the fuel line to install it. do i have any other options as to where to put it.
Postby Philip » Wed Sep 30, 2009 6:36 am
Just pickup a taped banjo bolt. That will give you provisions for hooking the gage. A taped banjo bolt is normaly taped for 1/8" pipe thread.
Postby 1STGENFARMBOY » Wed Sep 30, 2009 10:40 am
hay that sounds sweet where can i get one of those bolts, and back to the first question, will bigger cooler tubz and intake elbow help the egt problem, where i work we have a awsome machine shop and can make them.
Postby 93_Fummins » Wed Sep 30, 2009 11:06 am
An aftermarket exhaust manifold and 4-in exhaust helped my EGT's out a bit. Bigger tubes and free flowing intake would help a little too. I did the 60mm compressor upgrade and that just made things hotter for me. I got a lot more boost, but also more heat...mine, however, didn't have an intercooler though. Maybe look into water next...??? Or if you are feeling fancy and have access to it, a CO2 sprayer in front of the intercooler. I've yet to see a setup like that on a diesel, but I guess like any "bottle baby" upgrades, it only lasts so long...
93_Fummins
Postby 1STGENFARMBOY » Wed Sep 30, 2009 12:39 pm
I want to thank you gentelmen for the input thanks a lot, looks like im in for a 4in downpipe and some cooler tubz and an intake horn,Il try that i dont want to turn my pump down cuz i like smokin mustangs and spoiled brats.
Postby 921stgen » Wed Sep 30, 2009 4:03 pm
Here is the tapped bango bolt that will work.
http://www.genosgarage.com/prodinfo.asp ... ONG-TAPPED
You could also put in a powerstoke intercooler while doing everything else, Tim make the cooler tubz provisions for a powerstroke intercooler install.
921stgen
Postby 1STGENFARMBOY » Thu Oct 01, 2009 2:24 pm
Hay man! I just called genos garage and the man i talked to said it wouldnt work on a 1st gen truck. somebody please fill me in, i need a fuel preshure reading... thanks for the help :
Postby Richie O » Thu Oct 01, 2009 3:43 pm
1STGENFARMBOY wrote:Hay man! I just called genos garage and the man i talked to said it wouldnt work on a 1st gen truck. somebody please fill me in, i need a fuel preshure reading... thanks for the help :
I bought a fuel pressure gauge kit from them and that was part of the kit. For what its worth, there are no employes there that have a first gen so they are not up to par when it comes to 1st gen questions.
Postby PToombs » Thu Oct 01, 2009 5:54 pm
I have bought several there. If they ask, tell them it's for a p-pump truck, a 96 or something. They are all the same up to the CR engines.
Postby ontos » Fri Oct 02, 2009 8:43 am
You might want to turn down the pump until you get a better picture of the cause of the high EGT's. You can always turn it back up. 1500 or 1600 sounds pretty high.
How about the "air in" side of the deal?
I am a member of geezer world so I admit to driving it like I own it :)
89 5.9 non IC Freightliner motorhome Chassis 545 Allison
ontos
Postby Ace » Fri Oct 02, 2009 9:04 am
ontos wrote:I am a member of geezer world so I admit to driving it like I own it :)
I may be getting older, but I refuse to grow up! :)
Ace
Postby 1STGENFARMBOY » Fri Oct 02, 2009 11:21 am
Hay ONTOS when i got the truck it already had some of the mods like,ddp sticks fuel pin exaust housing changed but the pump was untuched till i got it then the fun begins, i know i could turn the pump down cuz before i turned it up i pulled 2 antique john deeres that both weigh 6500 lbs and i could mash the peddel to the carpet and hold it and the EGT'S would hit 1125 and thats it, that beeing said i can also control them buy liftin off the peddel, but i also drive it like i own it and love the new power, so I DONT WANT TO TURN THE PUMP DOWN. thanks for the input i do enjoy talking to all you gents. i dont know why i start every thred with HAY it makes me sound like gommer pile or somthing. :bh:
