ANOTHER FUEL PRESURE QUESTION
Postby 1STGENFARMBOY » Fri Oct 09, 2009 9:56 pm
I just put a mechanical fuel presure gauge on tonight, fired up the old truck and 3psi at idle :shock: :shock: :shock: got the threded banjo bolt from genos and put it post filter, Im going to put it pre filter in the morning and see what i have, Hopefully its a clogged filter.. OH BUY THE WAY IT DROPS TO (O) VERY FAST UNDER POWER. :pale:
Postby peobryant » Fri Oct 09, 2009 10:20 pm
Sounds about right for the stock lift pump. Stock should be about 3-5psi at idle, and with your mods, I'm sure you can easily pull it down to 0psi. Time for a piston lift pump. :D
Postby Richie O » Sat Oct 10, 2009 1:12 pm
I can pull the piston pump down to 3 psi. :D
Postby Ace » Sat Oct 10, 2009 2:05 pm
My FP runs around 16-17 and I can't get it below 15. :)
Ace
Postby PToombs » Sat Oct 10, 2009 5:52 pm
A stock LP should be 5-7 at idle, not less than 3psi at WOT. That's stock, of course. With your mods what you have is probably darn good! :lol:
Rich, time for a draw straw and bigger lines! ;)
Postby Richie O » Sat Oct 10, 2009 6:00 pm
PToombs wrote:A stock LP should be 5-7 at idle, not less than 3psi at WOT. That's stock, of course. With your mods what you have is probably darn good! :lol:
Nah! time to get some better, cooler air in it first. I hit 1500 easy today.
Postby 1STGENFARMBOY » Sat Oct 10, 2009 6:12 pm
Ok Richie How can my truck pull hard all the way to 85mph and show 0 psi from 20 mph on up im very scared of that,,, will it trash my pump or just start running crapy whin it starves for fuel :shock: :(
Postby PToombs » Sat Oct 10, 2009 6:12 pm
Shoot, I hit 1500 easy all the time! ;)
:finger:
Postby Richie O » Sat Oct 10, 2009 6:30 pm
1STGENFARMBOY wrote:Ok Richie How can my truck pull hard all the way to 85mph and show 0 psi from 20 mph on up im very scared of that,,, will it trash my pump or just start running crapy whin it starves for fuel :shock: :(
I drew my 93 down to 0 with the stock diaphram pump and the truck ran great. It is not good for the injection pump. That is why I upgraded. Some will run crappy when down to 0 psi. It retards the timing also when the case pressure gets low in the injection pump. So don't do it. :D
Postby 1STGENFARMBOY » Sat Oct 10, 2009 6:54 pm
So i read the post on piston lift pump upgrade using a 2nd gen and it shows a spacer and a new line going from the lift pump to the filter head is all that for a 2nd gen also, my 5 parts stores around here cant do nothin with cummins part numbers there pretty lame.. :x :x
Postby 1STGENFARMBOY » Sat Oct 10, 2009 6:57 pm
Also will my factory lines and tank pickup lines allow the fuel to flow or do i have to do the draw straw. :?
Postby PToombs » Sat Oct 10, 2009 7:09 pm
That's not a 2nd gen pump. It's an Ag application pump, low pressure. A 2nd gen pump puts out 25 -30 psi, which our IP's won't take.
You need the pump, spacer, line and 2 gaskets. You may also need to trim the insulation on the tappet cover with a utility knife for the line to clear. Upgrading to a draw straw is a good idea, but may not be necessary. Just change the pump and watch the pressure. Richie has stock lines and does ok with them.
Postby 1STGENFARMBOY » Sat Oct 10, 2009 7:16 pm
If i get the ag pump will i have to put a regulator on it ?? Because i was planning to put one on it to get it down to 15psi, that would great if i didnt need it. :?
Dumb question...
Postby MMeier » Sat Oct 10, 2009 7:45 pm
... where are you guys plumbing in a fuel pressure gauge ? I see this small plug on a banjo above the filter head, is that where you put it... alot smaller then 1/8 NPT, what size is that ?
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby 1STGENFARMBOY » Sat Oct 10, 2009 8:00 pm
Mat that small plug is the air bleeder, what you want is an aftermarket banjo from genos garage thats taped for 1/8th in pipe, and allso has 180th holes, stock one has 150th, :) Dar
