Help! Name this knock. (Videos)
Postby Darren A » Thu Oct 22, 2009 3:46 pm
It sounds like someones in my engine with a hammer.
The knock goes away when I crack the #6 injector line. I got the injector cleaned and popped, that didn't make a difference.
It's been doing it since ive bought it, can't figure it out.
See if you can hear it in these videos. Any clues?
http://www.youtube.com/watch?v=EQ-dhLweooQ
http://www.youtube.com/watch?v=cCjd3N2mi9U
Darren A
Postby ahale2772 » Thu Oct 22, 2009 3:49 pm
some thing inside the pump is making that injector missfire id say
Postby Richie O » Thu Oct 22, 2009 3:55 pm
The second link says its private.
Postby Darren A » Thu Oct 22, 2009 5:18 pm
Not private anymore
Darren A
Postby Darren A » Thu Oct 22, 2009 5:23 pm
I was hoping it wasn't pump issues.
Darren A
Postby Richie O » Thu Oct 22, 2009 5:23 pm
I don't hear anything out of the ordinary.
Postby Darren A » Thu Oct 22, 2009 5:25 pm
I've had a couple of people tell me they don't hear anything but others will notice it right away. It never used to bother me but it has lately.
Darren A
Postby burnt_servo » Thu Oct 22, 2009 5:31 pm
there's soething there , i would have to hear the truck in person to verify it though .......
my vw diesel makes a similar knocking noise ( it has a ve pump too ) .
the noise gets worse when the idle is lower , and when the fuel stations switch to #1 diesel .
it tends to go away with a slightly higher idle , and or when i add 2 or 3 litres of 2 stroke oil to the fuel .
for the most part i have ignored it for the last 3 years the car has great power and even better fuel millage , to i put up with how annoying it can be at idle .
something i was told by a old diesel mechanic years ago .....
DON'T worry about all the weird noise the engine may make , if you do it will drive you nuts .
'93 w250 .... stock ...
burnt_servo
Postby 921stgen » Thu Oct 22, 2009 5:35 pm
Have you adjusted the valves lately.
921stgen
Postby Oddfire » Thu Oct 22, 2009 5:45 pm
921stgen wrote:Have you adjusted the valves lately.
X2 8)
Oddfire
Postby Darren A » Thu Oct 22, 2009 6:11 pm
The guy I bought the truck from said he did them, which concerns me. LOL. I don't believe its a valvetrain noise because the sound goes away when I crack #6.
Darren A
Postby SNOOT » Thu Oct 22, 2009 6:55 pm
Converter bolts? Has the trans been out ??
1993 W350
SNOOT
Postby ahale2772 » Thu Oct 22, 2009 7:17 pm
well if its definitly # six then there is your issue have u cracked any others to see if the #6 injector sprays as much as the others?
Postby 1STGENFARMBOY » Thu Oct 22, 2009 7:31 pm
Trade holes with a diffrent injector, i definatly hear it in the first video, the idle sounds a little low to me, will it stop if you bump up the idle alittle.
Postby Mark Nixon » Fri Oct 23, 2009 11:11 am
Not saying this is how it is with YOURS, but if you have a "funny knocking noise" like that in a gasser and it goes away when you pull a plug wire (similar to cracking the line on a diesel), it's not a good sign.
It usually means a bad wristpin, piston, or the connecting rod is loose to the crank.
BUT we are talking diesel here, it's likely less dramatic.
