head gasket HELP
head gasket HELP
Postby dieselhotrodder » Thu Dec 10, 2009 8:23 pm
so i replaced my factory 225k mile seaping head gasket.... i have done a thousand head gaskets.. no problems..... until this one.. i did the proper seating proceedure and i drove ten miles down the road hit 25lbs of boost and then every ounce of oil in the motor waS ALL UNDER MY HOOD! and the dipstick was pushed out about a foot!!! what happened???? im beside my self!
dieselhotrodder
Postby crfsti » Fri Dec 11, 2009 12:30 am
wow, sounds like some how boost must be getting into the crankcase....but why? keep us updated on what you find out is going on with it!
crfsti
Postby Mark Nixon » Fri Dec 11, 2009 8:12 am
Sounds like the boost went partly into the crankcase?
Turbo tight and sealing?
Postby KTA » Sat Dec 12, 2009 8:02 am
Sounds like your head gasket blew compression. What brand gasket did you use? The ones from the parts houses like advance and napa are crap aka Federal Mogul.
Postby dieselhotrodder » Sat Dec 12, 2009 11:46 am
i used .010 thicker victor gasket.. my had has never been decked or anything.. could that of done it? i used the stock bolts that were checked for stretched..im racking my brains to figure out what happened
dieselhotrodder
Postby mprmn08 » Sat Dec 12, 2009 3:19 pm
how did they check them for stretch if they didnt know exactly how long they were new?
mprmn08
Postby KTA » Sat Dec 12, 2009 4:01 pm
I am not certain of the composition of that gasket. If there is nothing obvious out of whack I would try a new Cummins gasket put on with brake cleaned both surfaces and new bolts and see how that does.
Postby crfsti » Sat Dec 12, 2009 5:46 pm
I'd throw some ARP head studs in while your at it.
crfsti
Postby gear jammer 91" » Sun Dec 13, 2009 7:34 pm
I put three cummins gaskets and one victor reinz in my first gen. The victor reinz looked identical in every way to all the cummins gaskets I purchased. The victor gasket held 35 psi with no problems. The cummins gasket's blew for a variety of reason's. At least one blew from hitting 40psi cold, probably two. The last one blew from hitting 45psi+/- on a not quite warm engine. I also had issue's getting in a hurry and not sucking the oil out of the head bolt holes. Having oil in those holes when you torque the head down causes all kinds of issue's. Most people wouldn't have made that mistake, but sometimes I get in a hurry. :roll: I also had the head surfaced the first and third times I blew the gasket. I'm pretty good at changing head gasket's now. :lol:
01 LB7
gear jammer 91"
Postby dpuckett » Sun Dec 13, 2009 7:43 pm
Isnt Victor/Reinz the same as Federal/Mogul?
This is one time I'd go OEM.
Let the engine get up to temp before hitting the go pedal hard(ish) for the first time.
KTA- what are your thoughts on retorques? I skipped it on the 91; did two of them on the 92.5- once at the end of the first test drive; another time at about 300mi. Few bolts turned a little (<20deg), but that was about it.
DP
Postby KTA » Sun Dec 13, 2009 9:59 pm
Depends if you do the 120ft-lb method then I would do at least one re torque. If you do the Cummins torque turn method then no retorque.
