new 1st gen owner with a few questions
Postby silver91.5 » Sat Dec 12, 2009 6:37 pm
so i just got my first diesel its a 91.5 w250 5-speed reg cab. Anyways the odometer doesnt work, the speedo works and seems accurate but the odometer does nothing. Any ideas of what could be wrong? The truck is bone stock right now im wanting to do a few fueling mods such as a fuel pin and maybe a 3200 spring what are the best manufactures to go with? could you give me some links? Im not looking to get radical just wanting more low boost power. thanks
silver91.5
Postby Richie O » Sat Dec 12, 2009 6:58 pm
The odometer gears are most likley busted. :D
Postby silver91.5 » Sat Dec 12, 2009 7:59 pm
where are they (are they in the cluster?) how do i fix them? can i get the gears from a dealer or is it gonna be a junk yard item?
silver91.5
Postby Richie O » Sat Dec 12, 2009 8:06 pm
I have a link, never bought from them or have ever fixed one before.
http://www.carradio.com/speedometer_gears.html
re: broken odo gear
Postby firstgenjunkie » Sat Dec 12, 2009 9:45 pm
I used Southern Electronics (The link Richie posted above) when I rebuilt my speedo. They had great customer support and I got my parts in three days. The Sticky on DTR has a good VFAQ which walks you through replacing the gears.
http://www.dieseltruckresource.com/dev/ ... l?t=128685
Hope that helps.
Richard
1992 Dodge D350 Dually. EV2 Pyro & Boost, BHAF, Denny T Stage 2 pin, 366 spring, 4 inch exhaust and mildly tweaked pump. 2nd gen split bench, full replacement bumper/grill, and mobile comm suite.
firstgenjunkie
Postby silver91.5 » Sun Dec 13, 2009 3:11 am
ok well that helps me out alot ill try to get in contact with them, thanks guys
silver91.5
Postby Jfriedlin » Mon Dec 14, 2009 9:52 pm
Definitely spend the $16.95 on the 3200 spring, you wont be disappointed
Jfriedlin
