serpentine belt problems
Postby txs » Wed Dec 16, 2009 6:48 pm
Ok, I got the non air belt and tried putting it on, while it's a good bit shorter than the air version belt it's still that new railroad, Norfolk and Way. you sure there's not an extra idler I need to do the switch?
txs
Postby bgilbert » Thu Dec 17, 2009 2:28 pm
The nonAC belt is routed a different way. You probly don't have a diagram eh? Maybe someone can post one for ya, I've seen it online before.
Bill Gilbert
bgilbert
Postby txs » Thu Dec 17, 2009 3:45 pm
Bill, I figured out the routing but is it ok to run the grooved part of the belt over the flat pulley of the tensioner.
txs
Postby oldestof11 » Thu Dec 17, 2009 4:12 pm
No. It goes like this:
Crankshaft UP to FAN
FAN to ALTERNATOR
ALTERNATOR to WATER PUMP
WATER PUMP to IDLER
IDLER to CRANKSHAFT
The way you are doing it will make the belt come off. Ask me how I know.... :yuck:
This came off of my truck, cant be wrong.
Postby txs » Thu Dec 17, 2009 4:40 pm
That is the routing I used but the ribs are on the tensioner pulley, ain't no way to get it on the flat side of the belt, definitly don't want to screw up the new belt, freaking thing was 50+ $
txs
Postby Richie O » Thu Dec 17, 2009 4:42 pm
Phillip has a pic in his photobuckett account of the routing. If I can remember his account I will get it. 8)
Postby Richie O » Thu Dec 17, 2009 4:49 pm
Found it.
Postby oldestof11 » Thu Dec 17, 2009 5:41 pm
Sorry, my bad. I did it some other way and it popped off.
Postby PToombs » Thu Dec 17, 2009 6:26 pm
Tom, it won't hurt it any. Lots of belts run like that. If you're worried, you can get a grooved pulley.
Postby Ace » Fri Dec 18, 2009 8:47 am
Looks to me like standard setup (non-A/C) runs with grooves on the tensioner pulley.
Ace
