Fan Clearance
Fan Clearance
Postby Farmboy » Tue Dec 22, 2009 8:26 am
I tried to search this topic but I didn't find anything. I thought for sure someone would have posted this before...
Anyways, how much clearance should there be between the fan and the radiator. I have about 3/8" that doesn't seem like very much but I don't know how much it can go back till it will hit the engine oil fill tube. Keep in mind that I have a non intercooled engine with an intercooled front end on it. I am pretty sure Mark told me how different the fan supports are but I can't remember how much. I was going to try to make this work and not bother with the fan shroud, but if I have to I will change it. Any help would be appreciated.
Farmboy
Postby Richie O » Tue Dec 22, 2009 9:55 am
They are close enough for the engine to go through when plowing hard. :lol:
Postby Farmboy » Tue Dec 22, 2009 10:00 am
I take it this is from experience? :shock:
Farmboy
Postby Richie O » Tue Dec 22, 2009 10:02 am
Farmboy wrote:I take it this is from experience? :shock:
I used to work at a public works dept and they had a 89 that would jump the fan through the radiator. Manhole covers at 20 mph is not a good thing. :shock: That truck died an early death. The frame was bent so bad the doors would not open past the fenders unless you jacked up the middle of the truck. Humped it down in the middle. 8)
Postby Remps » Tue Dec 22, 2009 11:53 am
Hmmm... that's why I had to trim the heck outta my fan shroud! As far as the fan hitting the radiator,nothing to worry about there, unless maybe the truck is totalled like Richie's example. I also noticed my non A/C fan belt fit tighter on my N/IC truck than the I/C truck.
Postby Mark Nixon » Tue Dec 22, 2009 9:00 pm
Just checked and the carhauler, which has the intercooled fan, fan support and radiator is 3/4" to an inch away.
3/8" is very close, especially with a worn fan clutch.
The intercooled blades are actually thinner and the diameter of the fan is actually larger, as well, when compard to a non-intercooled fan.
Technically the intercooled 1st gen fan support is @ 1/2 shorter than the non-intercooled.
The non-intercooled support moves the fan forward, however, the PULLIES are offset to make the belt work between the 2 apps.
As far as the non-a/c belt being tighter on the non-intercooled, the fan support, obviously, sits @ 3/4" further to the driver's side on those engines.
Postby Farmboy » Wed Dec 23, 2009 5:20 am
I think I am going to wait until I get it back from the frame shop after the final tweeking of the frame. The nose of the frame does need to come down some so that will move the radiator further from the fan. We will see what it looks like then.
Farmboy
Postby BobS » Wed Dec 23, 2009 5:38 am
I have about 1-1/2 inches between the fan hub and the radiator in my IC'd version. Also see:
http://1stgen.org/viewtopic.php?t=6011& ... itting+rad
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
