direction of nut on back of fan .
Postby burnt_servo » Sat Dec 26, 2009 4:44 pm
need to remove the fan on a '93 12 valve ... and the fan on a 2002 24 valve engines .
with the wrench on the nut on the back of the fan , straight up and down , and facing the front of the truck . do i hit the top of the wrench towards the drivers side ( clockwise ) or to the passenger side ( counter clockwise ) to remove the fan ?
for the life of me i can't remember .... i'm also assuming both engines are the same with this .
thx :)
'93 w250 .... stock ...
burnt_servo
Postby pulltilbroke » Sat Dec 26, 2009 5:09 pm
Yes hit it towards the drivers side
Postby burnt_servo » Sat Dec 26, 2009 6:03 pm
thank you :)
burnt_servo
Postby Mark Nixon » Sat Dec 26, 2009 6:56 pm
I use a wide, long chisel, carefully started on one of the "flutes".
2 or 3 good whacks usually does it.
I gave upon the "proper" wrenches to do those long ago, when a guy used an air powered SNAP-ON set-up and failed.
2 or 3 whacks with a chisel, and I was a believer in "my way".
