which fuel filter?
which fuel filter?
Postby RumbleFish » Wed Jan 06, 2010 3:22 pm
so its time for a filter. which one do i want? i know there are several that i can use. long, short, with sensor, without, etc...
fwiw, i dont know if the WIF even works, ive never seen the light come on during the 'test'. im not opposed to doing away with it. any help, especially part #'s, is appreciated.
Postby bgilbert » Wed Jan 06, 2010 5:46 pm
Don't you listen at SOP? :lol: FS1221 or equivalent is the longer filter with drain and no provision for WIF sensor. FS1232 is stock IIRC.
Bill Gilbert
bgilbert
Postby PToombs » Wed Jan 06, 2010 6:15 pm
He doesn't listen at all. Must be you weren't paying attention either. :lol:
I have a FS19773 on mine. It fits a new backhoe, I think it's a finer micron, but I can't find out from the Fleetguard site. It's a long one and has the water drain too.
Postby RumbleFish » Wed Jan 06, 2010 6:35 pm
its hard to remember much past the screwing i took on that starter. do i still owe you for it bill, or are we square?
oh, i DO remember the filter you got from tim. thats a bit bigger than i am after. ill check the prices on these fleetguard filters. chances are, tho, ill be running a wix due to my discount.
anybody else?
Postby Ace » Wed Jan 06, 2010 6:37 pm
That FS19773 crosses to a Wix part# with a 14um rating. They are usually pretty good about supporting OEM spec and accurate cross-reference, but I don't trust them after they changed the rating on the one I was using as my secondary at some point in the past year or so.
Just something to think about....
Ace
Postby PToombs » Wed Jan 06, 2010 7:00 pm
What's the micron of the FS1221? I kinda thought it was 10?
Postby Ace » Wed Jan 06, 2010 8:52 pm
The 1221 crosses to the same 33472 Wix. The stock filter is supposed to be a 10um nominal filter.
This is why I switched over to the true Racors last summer. Filter ratings have gotten confusing and I don't trust even the big-name manufacturers like Fleetguard, Baldwin and Wix to reliably support the OEM specs anymore, especially after what happened to all the commonrail injectors over the past few years.
I don't really know what's going on, but I suspect alot of the manufacturing has moved overseas with a corresponding drop in quality control. I also suspect Wix for one, may have simply de-rated alot of their filters for that reason with no regard for the users who did not know what they were getting.
Ace
Postby PToombs » Thu Jan 07, 2010 6:34 pm
Ok, thanks. So the one I am running is actually larger (allegedly) than the stocker, that sucks! I guess it's time to swap it back, or find a finer one..
