Fuel pressure gauge question
Postby PRINCETON_JAKE » Sat Jan 09, 2010 3:49 pm
I have a 1992 dodge cummin that i want to install a mechanical fuel pressure gauge on. I already bought the gauge and hardware, including a tapped banjo bolt fron genos garage. Is the banjo bolt sopost to go on the line from the lift pump where it connects to the filter housing? Is it possible to connect it after the fuel filter so I get a more acurate reading? Does anyone know the thread size for the fuel bleeder screw? Can I adapt the gauge to it?
Thanks, Jake.
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby Richie O » Sat Jan 09, 2010 5:36 pm
The banjo bolt replaces the bleed screw banjo.
Postby PRINCETON_JAKE » Sat Jan 09, 2010 5:54 pm
I didnt pull it out because the banjo bolt I got from genos looked bigger, I guess I'll try it tomarro. Do you have any pictures or links? I found a deal on a set of Bosch 190 injectors, but I've read they dont make an improvement, any input? My truck is a 1992 innercooled.
PRINCETON_JAKE
Postby Richie O » Sat Jan 09, 2010 6:40 pm
I never have run 190's but hear they are good for a slight upgrade. If you want lots of power go bigger. No pics of the fuel banjo. I should get one, your the 2nd one in 2 days to ask for one. :D
Postby PRINCETON_JAKE » Sat Jan 09, 2010 6:49 pm
Im going to try tomaro.
Can you check out my post in the injector sticky.
Thanks, Jake.
PRINCETON_JAKE
Postby PRINCETON_JAKE » Sun Jan 10, 2010 5:43 pm
The bolts were the same size. I put in the genos garage banjo bolt and got the mechanical gauge hooked up. The fout cross drilled holes in the new bolt are quite a bit bigger, which should help flow more fuel. I also noticed that two of the holes were blocked on the old bolt do to overe tightening it are squezing the rubber washer. After i was done I had to take it for a drive to see what kind of pressure i had, before I install the new piston lift pump. At idle the highest pressure i ever saw was 5.5psi, accelerating it quickly drops. Anything over 3/4 throttle it dropped below 0psi!!! I hope I havent done any damage, I will be installing the new pump as soon as ot shows up.
PRINCETON_JAKE
Postby PToombs » Sun Jan 10, 2010 6:07 pm
That's about normal for a whipped stock pump. You'll be surprised with the piston LP. The truck will run better too. ;)
Postby PRINCETON_JAKE » Sun Jan 10, 2010 6:12 pm
The piston pump is on order, the pump on it right now is a brand new carter diafram pump.
PRINCETON_JAKE
Postby PToombs » Sun Jan 10, 2010 6:31 pm
Have you changed the fuel filter lately? If that gets plugged it can do it too. FSM says 5-7 psi at idle, not less than 3 psi at WOT.
Postby PRINCETON_JAKE » Sun Jan 10, 2010 6:54 pm
Brand new wix fuel fiter. Those specs are probably for a stock truck. Mine smokes. :D
PRINCETON_JAKE
Postby 93DodgeCummins » Mon Jan 11, 2010 3:21 pm
Where do you guys buy new lift pumps for first gens. cuz i think mine is going out. Whats part number for the banjo bolt from genosgarage?
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Postby PRINCETON_JAKE » Mon Jan 11, 2010 4:03 pm
heres the "tapped" banjo bolt, aslo tell them you need 2 washers/seals, there extra but only like $1. DONT reuse your old ones. Even though it says 98.5 and newer it is the right one.
http://www.genosgarage.com/prodinfo.asp ... ONG-TAPPED
I can get you all the NEW part numbers for the pump and parts, to convert it to a LOW pressure PISTON style pump. Its not worth putting on a factory style pump, I tried that and it doesnt flow enough.
PRINCETON_JAKE
Postby 93DodgeCummins » Mon Jan 11, 2010 6:40 pm
I only have stock fuel settings, but sometime in the future that will change. Will the different style lift pump be okay for stock injector pump and stock settings?
93DodgeCummins
Postby 921stgen » Mon Jan 11, 2010 7:16 pm
93dodgecummins, yes it will be fine w/ a LP lift pump or a HP lift pump w/ regulator.
921stgen
Postby 93DodgeCummins » Mon Jan 11, 2010 9:13 pm
where can i find lift pumps?
93DodgeCummins
