WATER PUMP HELP
WATER PUMP HELP
Postby PRINCETON_JAKE » Mon Jan 11, 2010 7:28 am
THE WATER PUMP ON MY 92 HAS BEEN LEAKING A LITTLE, SO I WAS GOING TO PUT ONE IN TODAY. tHE PROBLEM I HAVE IS i CAN GET ONE WITH 5 OPEN BLADES OR ANOUTHER BRAND WITH A SHIELD THING OVER THE BLADES. I DONT HAVE MINE APART YET TO SEE WHAT IT HAS. WHICH SHOULD I USE, DOES IT MAKE A DIFERENCE?
ONE MORE QUESTION, WHERE IS THE FUEL HEATER LOCATED ON MY TRUCK?
1992 cummins, 2wd, A518, WH1c, 60mm,12cm housing, fuel screws maxxed, fuel pin turned and ground, 3200rpm spring, big Amsoil air filter, 4" stack, timming bumped, piston lift pump, Bosch 190's, 18" Maxxi Hulk rims, and Nitto Terra Grapplers.
PRINCETON_JAKE
Postby Ace » Mon Jan 11, 2010 7:36 am
I remember seeing somewhere recently where the shielded pump was reported to be the better design. No 1st hand knowledge on that, tho...
Fuel heater is above the filter.
Ace
Postby PRINCETON_JAKE » Mon Jan 11, 2010 9:47 am
I CANT FIND ANY THINNG OUT ABOUT THE DIFFERENT DESIGNS.
I WAS TOLD TO CHECK OR CLEAN THE SCREEN IN THE FILTER HEATER.
PRINCETON_JAKE
Postby Ace » Mon Jan 11, 2010 10:13 am
The heater and filter are two different units, with the heater sandwiched between the filter and the mount up under the manifold.
Ace
Postby IowaCummins » Mon Jan 11, 2010 12:21 pm
a year ago i went to cummins and bought theres. i think its was just fins so it must be a open design?
IowaCummins
Postby oldestof11 » Mon Jan 11, 2010 4:42 pm
Non IC have open, IC have shielded. I heard the IC's flowed more...
Postby PToombs » Mon Jan 11, 2010 6:33 pm
The p-pump trucks have a pre-strainer and fuel heater. It goes from there to the LP then the regular filter. All you have is the regular filter and the heater is above that. No cleaning neccessary.
Postby PRINCETON_JAKE » Mon Jan 11, 2010 6:45 pm
thanks!
PRINCETON_JAKE
Postby 921stgen » Mon Jan 11, 2010 7:12 pm
Heres a recent post on water pumps. http://www.dieseltruckresource.com/dev/ ... erid=64476
921stgen
Postby PRINCETON_JAKE » Mon Jan 11, 2010 7:31 pm
thanks!
PRINCETON_JAKE
Postby cumminspuller98 » Tue Jan 12, 2010 9:34 am
oldestof11 wrote:Non IC have open, IC have shielded. I heard the IC's flowed more...
are you 100% sure about that?? from what i have found(first hand) pre94 trucks have the shilded, unless the water pump has been replaced. 95 and up have the open style pump like your talking about. in which case the new style open pump, pumps more.
cumminspuller98
