turbo whine
turbo whine
Postby stock91w350 » Sun Jan 17, 2010 6:49 am
is it normal that i do not hear the turbo whine intill it has been running for about 5-10 minuts, when i firdt start it ther is no whine and when i come back outside minuts later u can her it whisteling threw the stack
stock91w350
Postby RSWORDS » Sun Jan 17, 2010 8:43 am
When the ngine is cold (sitting all night) pull off the aire intake tube and try to spin the wheel... It should spin very easy.
RSWORDS
Postby stock91w350 » Sun Jan 17, 2010 6:03 pm
yup it spins easy, is it normal for the turbo whistel to start being heard a couple minuts after the first start up of the day?
stock91w350
Postby Richie O » Sun Jan 17, 2010 6:17 pm
Until stuff warms up it will act different.
Postby FRadisi » Sun Jan 17, 2010 8:55 pm
It's normal. I can start my truck cold and not hear the turbo through my stacks, but let it sit and warm out and you can definitely hear the turbo over the exhaust.
FRadisi
Postby rattlebox93 » Tue Jan 26, 2010 9:09 pm
the cold engine oil is thicker and therfore the turbo is not going to spin as fast when the engine is cold
rattlebox93
