DZL_Damon wrote:I can't do a picture now, as the engine bay is torn apart. However, the bar goes fore to aft. It's just a 1/2" wide bar that has a small bend in the end like an L. This small L end goes in a hole made on the front part above the headlight (IDK if this little hole was stock or not). The L points up so it's locked. There is a hole drilled into the other end (facing aft). A threaded rod is made into a J shape and the J hooks into the back of the battery tray. It goes up and through the hole. I need to do something a little different because it makes a squeeking noise.
I just reread this and it seems VERY confusing! I'll try to remember to drop the batteries in tomorrow and take a picture for you.
Richie O wrote:Is it like a margin plate or a web frame in the tween deck? Or a breast hook in the forepeak.Sorry , could not resist. Just sounded a little boaty.
DZL_Damon wrote:
Sorry to say Rich, you remind me of my girlfriend
