how to replace oil pan gasket???
Postby rawpower » Wed Apr 14, 2010 3:18 pm
My 89 has an oil leak & my hanynes book doesnt say hoe to change the oil pan plz help.
jake ladd
sebring florida
1989 project d250
rawpower
Re: how to replace oil pan gasket???
Postby Tintacker » Wed Apr 14, 2010 8:33 pm
I don't know what the crossmember looks like on a d250 but o a w250 it's quite a job. If it's not leaking enough to drip, fuhgettabouditt. Try re-torquing the pan bolts and cross your fingers.
On my w250 I had to unbolt the engine mounts, jack the engine as high as I could, unbolt the crossmember and drop it as low as possible.
That gave me enough room to drop the pan a couple inches, barely enough room to reach in and unbolt the oil pickup tube then slide the pan out.
Very difficult on re-assembly, especially when everything needs to be CLEAN!
Good luck
SOLD: :( '92 W250 LE auto PDR 190's, 3200 spring, Skyjacker 2" front springs with Bilstein 5100s
'01 2500 QC/SB 4X4 6sp, camper puller
Tintacker
Postby PToombs » Thu Apr 15, 2010 6:10 pm
On the D it's even worse, no place to drop the pan to. You can probably do it in chassis, but I bet it's faster to pull the engine out.
Look real close and make sure where the leak is from. The timing case may be loose and leaking from there.
Oh, use the Haynes manual to soak up the oil in the drive way and get yourself a good Factory Service Manual. They are around $100 give or take most places. I got mine from Geno's Garage.
Postby soggy » Thu Apr 15, 2010 9:02 pm
X2 on ditching the haynes and getting a FSM.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Postby DieselSharker » Mon Apr 26, 2010 3:28 am
x3. Hayne's has never been helpful to me in any of my vehicles. FSM was the best $100 I've ever spent on my truck and makes pretty easy work of everything I have had to repair.
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Postby Mark Nixon » Mon Apr 26, 2010 7:02 am
For all the effort, I'd be more likely to yank the whole thing and re-seal the pan that way.
Think of it this way, you have the thing half way out anyway when you lift or jack it up, what's a couple lines, an exhaust clamp, a few bellhousing bolts and some wires?
And a hood?
An hour more?
Postby FRadisi » Mon Apr 26, 2010 2:47 pm
Mark Nixon wrote:For all the effort, I'd be more likely to yank the whole thing and re-seal the pan that way.
And a hood?
An hour more?
Exactly, I'll be pulling the motor out to do my gasket as well. The block is also going to be painted and some leaks will be fixed :D
To the OP, if you have any other repairs/maintenance/leaks to fix... go ahead and pull the motor, you'll be glad you did.
FRadisi
