I have two (that I know of) fuel leaks on my motor. One is coming from the transfer pump, which I guess I just need to replace the gasket, and the one I'm trying to pinpoint is coming from the back side of the injector pump. I'm not sure if it's coming out of the block or maybe the gasket between the timing case and pump needs to be replaced. Does anyone know if fuel would be leaking out of the plate on the block behind the pump?
Also is the drain on my fuel filter supposed to be damp all the time? I don't see fuel dripping from it but it's definitely not dry.
Where can I get the extender for the oil fill tube?
I'm sure I have more questions but that's all I can think of right now.
