How to make a valet switch?
Postby FRadisi » Sun Apr 25, 2010 4:32 pm
I can't find any definitive how-to and was wondering if anyone knew how to make a valet switch on the boost line to the AFC?
FRadisi
Re: How to make a valet switch?
Postby PToombs » Sun Apr 25, 2010 4:44 pm
Piece of cake! Get a solenoid, I used a 6JJ52 from Graingers, 12 volt, 1/8 npt ports. You need to put it in line with the AFC hose. The head is 1/8npt, so get fittings and hose to connect the solenoid. I used the original line from the soleniod to the AFC, and the hose from the head to the solenoid. Some people rethread the AFC hole to 1/8 npt, easy to do, I didn't want to. Just plumb it in, wire it to a switch, and turn it on when you need to. I'll find pics and post them for you.
Postby FRadisi » Sun Apr 25, 2010 5:15 pm
Thanks for the info and pics Pete!
Just one question, how does the solenoid work? Does it have some internal "flapper" that cuts off a lot of the boost going to the pump?
FRadisi
Postby DieselSharker » Mon Apr 26, 2010 3:24 am
Bahaha I see at least one person listens to me. I know of a thread from someone who made one with just the air lines and a ball valve and ran it into the cab if you'd like me to look for it. That's what I was going to do because anything with wire scares the crap out of me lol.
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Postby PToombs » Mon Apr 26, 2010 6:02 pm
It's just a plunger that goes up when the coil is energized. It may have an o-ring on it. I never took it apart to see because it works, and I like it that way. ;) :mrgreen:
Chris, I thought they did drug testing in the service? Or did you start when you got out? :lol:
j/k ;) That's a real 1/2 assed way to do it, the long lines add a delay before the cone starts to move. I guess sometimes you have to work with what you have. ;)
Postby DieselSharker » Mon Apr 26, 2010 6:31 pm
PToombs wrote:It's just a plunger that goes up when the coil is energized. It may have an o-ring on it. I never took it apart to see because it works, and I like it that way. ;) :mrgreen:
LOL I thought about that too, that's why I haven't done it yet. I have a lot of work to do the next couple weeks between putting the rear end together, changing the head gasket, putting the 60mm wheel and housing on and putting my tach in finally, might as well do that too.
Edit: I looked up that part number and it's like $34 so looks like I'll just go with the switch. Screw drilling more holes in my firewall for the hoses.
DieselSharker
Postby huntinguy » Mon Apr 26, 2010 6:36 pm
I was thinking about making a valent switch with a off and a half off setting. That way I could limit the power but not shut it all the way off. Would that work?
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby PToombs » Mon Apr 26, 2010 7:12 pm
I'm not sure how that would work. The solenoid is either on or off. If there was a way to give 1/2 flow, it would still build enough pressure to push the cone down, just slower. You almost need an electric actuator you can set the stops on, off, 1/3, 1/2, 3/4, full or whatever.
Postby Richie O » Mon Apr 26, 2010 7:40 pm
You could rig a boost fooler but I would take 2 valves to do it.
Postby JBradley500 » Wed Apr 28, 2010 6:35 pm
PToombs wrote:That's a real 1/2 assed way to do it, the long lines add a delay before the cone starts to move. I guess sometimes you have to work with what you have. ;)
i did it that way. i worried about the delay too. it turns out with 1/4 tubing, 40 psi of boost and 8' of tubing (or less) the delay would be .004 seconds before the entire tube was pressurized. i couldnt figure it out myself, i had to have help with the calculations. i dont think there is a disadvantage to the long lines with the valve compared to the electric besides you have to drill holes for the tubes.
its not half assed just because you didnt do it the same way.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500
Postby PToombs » Thu Apr 29, 2010 7:30 pm
JBradley500 wrote:its not half assed just because you didnt do it the same way.
That's not why I said it at all. :roll: I applaud somebody doing something different if it's decent and gets the job done. I also understand trying to do things with no money to spend on it.
I said it because it looks like a farmers cob to run 2- 1/4" tubes up thru a hole hacked in the firewall to a valve wired to the dash.
Postby JBradley500 » Fri Apr 30, 2010 2:14 pm
Well i cant say it looks perfect if youre underneath the dash looking for it but its practically hidden from view from any normal position youd be in the truck unless you were 4' tall. I wasnt trying to start anything. I did it that way because its simple, reliable, functions the same as an electric and it was only like 20 dollars. I couldnt justify spending 60 dollars more because i would rather run electrical wires than 1/4" tubing, and have a switch instead of a valve. I guess to each his own but i just dont think its half assed, maybe my use of wire ties isnt optimal but its not like i used self tapping screws into the dashboard or something.
JBradley500
Postby RumbleFish » Fri Apr 30, 2010 5:14 pm
JBradley500 wrote:...but its not like i used self tapping screws into the dashboard or something.
this is my truck. you should see all the screws, glue, and jb weld holding my dash together. and its still all broke to hell. im proud to say im responsible for none of it.
Postby PToombs » Fri Apr 30, 2010 5:47 pm
I know the previous owner! :lol:
Not necessarily saying that he did it either, just saying I know him. ;)
Postby Towrocket » Fri Jul 02, 2010 11:19 am
What I used http://www.clippard.com/store/display_d ... ku=MJTV-3#
And the lag if any isn't very noticable. Plus I added a T for my boost gauge under the dash.
Pic if the link don't work. It's been called a "ghetto nitro switch" in my neck of the woods :ncool:
89 W250, SC, SRW, Daily Driver (mostly stock)
Towrocket
