PToombs wrote:It's just a plunger that goes up when the coil is energized. It may have an o-ring on it. I never took it apart to see because it works, and I like it that way.![]()
Chris, I thought they did drug testing in the service? Or did you start when you got out?![]()
j/kThat's a real 1/2 assed way to do it, the long lines add a delay before the cone starts to move. I guess sometimes you have to work with what you have.
PToombs wrote:That's a real 1/2 assed way to do it, the long lines add a delay before the cone starts to move. I guess sometimes you have to work with what you have.
JBradley500 wrote:its not half assed just because you didnt do it the same way.
JBradley500 wrote:...but its not like i used self tapping screws into the dashboard or something.
RumbleFish wrote:JBradley500 wrote:...but its not like i used self tapping screws into the dashboard or something.
this is my truck. you should see all the screws, glue, and jb weld holding my dash together. and its still all broke to hell. im proud to say im responsible for none of it.
