My "new" 1993 project/daily driver! :D
Re: My "new" 1993 project/daily driver! :D
Postby PToombs » Sun Sep 30, 2012 4:51 pm
He found a candy wrapper that you left behind stuffed in something ? :lol:
Postby Mark Nixon » Sun Sep 30, 2012 5:04 pm
PToombs wrote:He found a candy wrapper that you left behind stuffed in something ? :lol:
I dunno whether to :lol: or :shock:
Hilarious.
Postby bmoeller » Sun Sep 30, 2012 5:10 pm
Naw. I didn't have the high pressure line for #5 tight on the back of the IP. I had the wrench on it. Thought I had it done up. NOPE. Got it snugged up, and smoothed right out after I cracked it loose on the other end to get the air out. Thought it had been tight. Guess I wound up hitting against one of the other fittings with the wrench. :roll: Oh well. Running DAMN good now! :D Better now, that even when I drove 'er home from Mark's after I bought it. :D With the bumped timing and the BD fuel pin, it's like a whole new truck. :D Doesn't dog down letting out the clutch at idle (even in 1st) anymore either. :D Never touched the idle setting. Sounds really good with the timing bump, too. :D
Also, removed the ratio box. Now, the speedo is only 5mph slow, vs almost 50% with the box in place. Was one in a bag of parts that came with the 92. Tried it for the heck of it. WAY off. :lol:
Turbo drain gasket still leaking. :roll: New gasket and loctited bolts. Both surfaces clean and smooth.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Farmboy92_2009 » Sun Sep 30, 2012 7:28 pm
hmmmmm :oops: :roll: :roll:
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
Postby bmoeller » Sat Nov 03, 2012 12:43 pm
Nothing done for a while. Have a few goodies to put on, but haven't had time yet. :roll: Picked up a chrome skull shifter for the truck today. :)
bmoeller
Postby tampabayBill » Sat Nov 03, 2012 4:38 pm
A CHROME SKULL SHIFTER ?? Glad to see you are making progress !
Twins coming soon!
tampabayBill
Postby tampabayBill » Sat Nov 03, 2012 8:31 pm
Sorry Bryan, I just couldn't help myself.
Twins coming soon!
tampabayBill
Postby Tacoclaw » Sat Nov 03, 2012 9:28 pm
In all fairness his chrome skull shift knob is way more progress than I'm making. :lol:
Postby bmoeller » Sat Nov 03, 2012 9:40 pm
It isn't even IN the truck right now! :lol: Sitting next to me by my computer. :lol:
bmoeller
Postby Tacoclaw » Sat Nov 03, 2012 10:00 pm
You're still ahead of me, I'm waiting on an adapter to go from -6 JIC to the M12 that the H1c uses. Just be sure to keep that knob polished up (I assume that's why you've got it beside your computer), you want it in it's prime when you put it on your truck.
Postby bmoeller » Sun Nov 04, 2012 4:44 pm
If you call that being ahead of you, you should see the pile of shti I have on the floor and behind the seat waiting to go on. :lol:
Air compressor, air horns, used BD exh brake, visor, shelf,........................
bmoeller
Postby PToombs » Sun Nov 04, 2012 5:21 pm
Levi just likes the thought of you sitting at your computer polishing your knob. ;)
Postby Tacoclaw » Sun Nov 04, 2012 5:31 pm
I tossed that out there just for you, Pete, I knew you'd appreciate it.
Postby Mark Nixon » Sun Nov 04, 2012 5:35 pm
I am SOOOO glad all of you guys think and act like I do!
A dirty mind is a TERRIBLE, TERRIBLE thing to waste!! ;)
Postby PToombs » Sun Nov 04, 2012 5:38 pm
:jumpsmile:
