Guess Its about time...
Re: Guess Its about time...
Postby dazedandconfused » Tue Dec 13, 2011 5:55 am
Ouch that piston doesn't look good. Did you throw a gauge on it to check compression after putting it back together? I wonder if that's what caused the headgasket to let go. Is that on the edge facing 2 or 4
Postby ahale2772 » Tue Dec 13, 2011 6:09 am
no, havnt checked the compression, might swap the injectors soon, if i do, ill check it then.
it didnt look to bad, I think its a nick from the piece of fire ring that fell off, im guessing thats made its way through the turbo somehow... :/
valve looked good, seat looked ok.
any idea what the propper compressin should be?
when i check ed them before, (of course the only ones i checked were 2 and 3) I only got 100lbs when the headgasket was junk
need to swap back to my old injectors, of course those are all dirty now... UGHH
Postby ahale2772 » Tue Dec 13, 2011 6:12 am
and that is the edge facing 2, right where the gasket blew between 2-3
Postby ellis93 » Tue Dec 13, 2011 6:53 am
Alex a 100lbs is super low for a diesel engine,I know the gasket was blown. I looked this morning on my mitchell and I got the old "info not available" so I'll say this, a PSD with less than 250lbs of compression HAS to have ether to start. I would suspect that the compression psi of our motors should be 300 or better to ignite the fuel.
Postby dazedandconfused » Tue Dec 13, 2011 7:02 am
I've seen people post readings of 350-380 but I don't recall if that was low or normal.
Postby ahale2772 » Tue Dec 13, 2011 7:50 am
ellis93 wrote:Alex a 100lbs is super low for a diesel engine,I know the gasket was blown. I looked this morning on my mitchell and I got the old "info not available" so I'll say this, a PSD with less than 250lbs of compression HAS to have ether to start. I would suspect that the compression psi of our motors should be 300 or better to ignite the fuel.
yeah, your right, but that was testing it with the bad gasket, i need to check it with the new one. Thats how i diagnosed the issue, #2 and #3 would leak right into each otherm, and out whatever valve was open on the other cylinder. I could hear air pouring out of the exhaust, and right out of the intake
BTW the sire has told me network error 4 times, and reverted me to writing this comment over...4 times.... my fingers hurt
Postby ellis93 » Tue Dec 13, 2011 7:58 am
I found were a guy did a compression test on his motor and got 425
Postby ahale2772 » Tue Dec 13, 2011 8:00 am
yeah, think I might have seen the same link, maybe cummins will have a figure in their books, but I doubt it if they encourage a leak down test instead
Postby Tacoclaw » Tue Dec 13, 2011 10:21 am
ahale2772 wrote:another thing, does anyone know of a cummins P/N to eliminate the fuel heater thing at the top of the filter? mine leaks neer the top gasket, couldnt find the propper adaptor to eliminate it
would be nice to run a taller fuel filter
Tsk Tsk, the chain continues. :lol:
viewtopic.php?f=1&t=11221
Postby ahale2772 » Tue Dec 13, 2011 10:37 am
:lol: :shock: what have I done...
Postby chrislib » Tue Dec 13, 2011 10:50 am
The edge of that piston looks like it might have gotten a bit scorched when the gasket popped, hopefully someone with more smarts than me`ll chime in.
It`s not about how hard ya hit...it`s about how hard ya can GET hit and keep movin forward.
93 W250 CC 4x4, Auto,7x010`s, D-Zilla/16cm, 5in exh, BHAF/Smoky...don`t call it ratty, that`s patina son!
chrislib
Postby PToombs » Tue Dec 13, 2011 6:09 pm
Compression around 400 is ok. It's more important that they are within about 20 psi of each other. It will run at 350, but with one at 200 it will skip like a SOB. ;)
