steel tank weight?
Postby wjones » Sat Jun 27, 2009 11:12 am
this is why they made low range :D
1992 W250, nv4500 Club Cab
wjones
Postby Begle1 » Sat Jun 27, 2009 11:36 am
I think I'd at least cut it in half...
Blow torches are pretty portable, thankfully.
Postby swank » Sat Jun 27, 2009 10:33 pm
What in god's name are you going to do with this?
truck
swank
Postby Ace » Sun Jun 28, 2009 1:14 am
I'd estimate scrap value at about $2k. 8)
Ace
Postby swank » Sun Jun 28, 2009 9:25 am
Ahso. I had filling it with grease for the Mercedes on my mind.
truck
swank
Postby meby » Fri Jul 03, 2009 8:02 am
IowaCummins wrote:begle i was thinking the same as you. plus with all the sedament in the bottom of the tank from years of use then all teh years of sitting. i forgot to ask but hopefully i will monday. so another question. do you guys think my truck can haul it? it only going to be a max of 10 miles and through the city. a buddy has a dual tandem axle goose neck 30 footer. i have to find out what the max weight of the trailer is but you think my truck can do it? good holding power tranny auto. then i just did the brakes all around with the 1 ton shoes and big wheel cylinders. im pretty sure the trailer has brakes on both axles but defffinately one. is this a good idea or should i cut her up onthe spot?
Whats the rating on the axles? Even with heavy axles, you would likely be pushing the limits a bit.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
