IowaCummins wrote:begle i was thinking the same as you. plus with all the sedament in the bottom of the tank from years of use then all teh years of sitting. i forgot to ask but hopefully i will monday. so another question. do you guys think my truck can haul it? it only going to be a max of 10 miles and through the city. a buddy has a dual tandem axle goose neck 30 footer. i have to find out what the max weight of the trailer is but you think my truck can do it? good holding power tranny auto. then i just did the brakes all around with the 1 ton shoes and big wheel cylinders. im pretty sure the trailer has brakes on both axles but defffinately one. is this a good idea or should i cut her up onthe spot?
