cmann250 wrote:What up, gentlemen?
PToombs wrote:Swap it! then you will be welcome at the 1st gen meets again! And it will make it there too!
Philip wrote:PToombs wrote:Swap it! then you will be welcome at the 1st gen meets again! And it will make it there too!
Now Pete he didn't have trouble getting there. It was the leaving part he had problems with.![]()
DodgeFreak wrote:Could be, I replaced that when I done the belt and last head. The whole upper end and oil pump has 40k on it. I need to jack the car up high enough to get it slid out now. I'll check it over and see if i can figure it out.
RumbleFish wrote:DodgeFreak wrote:Could be, I replaced that when I done the belt and last head. The whole upper end and oil pump has 40k on it. I need to jack the car up high enough to get it slid out now. I'll check it over and see if i can figure it out.
Do the water pump while its out anyway. Did you replace the tensioner? Is it the mechanical style? Ive seen a couple of them lose tension for no apparent reason.
Farmboy wrote:Ok... Brakes... They are currently defeating me.
Symptoms:
first time you put your foot on the brakes the pedal goes straight to the floor. Pump it 2 to 3 times more and you can get a decent pedal, not good but decent. leave your foot there and the pedal slowly but steadily goes to the floor, bleeding off like there is a hole in the line.
absolutely no fluid making it to the ground anywhere.
So I started off by replacing the master cylinder. No change
Next.. bypassed the ABS valve on the rear frame including a new line from the proportioning valve in the front to the rear axle. NO CHANGE!
All new brakes were installed in the back when I swapped in the dually axle. And a new right front caliper was installed a few months ago when i snapped off a bleeder trying to resolve this issue the first time.
Only thing not new is the left front caliper...
Any suggestions?!?!?!?
PToombs wrote:Yup, I usually adjust mine up so they just drag and then call it good.
Philip wrote:PToombs wrote:Yup, I usually adjust mine up so they just drag and then call it good.
I just fix mine so they work properly. All you cheap skates.![]()
