Popping noise.
Re: Popping noise.
Postby Bsmith909 » Sun Jul 08, 2012 12:19 am
My truck had a popping noise, until I fixed it earlier today. I replaced the u joints in the driveshaft and all the popping while turning and backing completely stopped. Plus if you haven't changed them recently or don't grease them often it's a cheap fix and would be well worth the time anyway.
Bsmith909
Re: Popping noise.
Postby meby » Sun Jul 08, 2012 6:38 am
Bsmith909 wrote:My truck had a popping noise, until I fixed it earlier today. I replaced the u joints in the driveshaft and all the popping while turning and backing completely stopped. Plus if you haven't changed them recently or don't grease them often it's a cheap fix and would be well worth the time anyway.
Mine only happened when I would turn the steering wheel to full lock (2wd). I've changed all the rears and the carrier bearing too. :D
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Re: Popping noise.
Postby Mark Nixon » Sun Jul 08, 2012 6:40 am
On a 2wd, check the radius rod bushings.
Re: Popping noise.
Postby meby » Mon Jul 09, 2012 5:21 pm
Mark Nixon wrote:On a 2wd, check the radius rod bushings.
Did all them too. :mrgreen:
-Case 530 CK
www.ebyfarmsllc.com
meby
Re: Popping noise.
Postby Mark Nixon » Mon Jul 09, 2012 5:25 pm
How about upper and lower BUSHINGS? Balljoints? :D
Sometimes the bolts in the radius rods-to-control arms just creak when you lock to lock it.
Re: Popping noise.
Postby meby » Wed Jul 11, 2012 3:41 am
Mark Nixon wrote:How about upper and lower BUSHINGS? Balljoints? :D
Yup and yup. I did everything from...okay, its easier to say the only things I haven't touched yet are the steering gearbox and two tie rod ends that were in good shape. Everything else and I mean everything else was changed. :mrgreen:
-Case 530 CK
www.ebyfarmsllc.com
meby
Re: Popping noise.
Postby Mark Nixon » Wed Jul 11, 2012 7:28 am
Well then, if the obvious is done, then what remains undone, no matter how implausible, must be causing the noise.
Check the box for excessive play near the end of the left turn and check the coupler for slop.
You might also check the front of the frame where it's riveted together, in front of the box.
Re: Popping noise.
Postby oldestof11 » Wed Jul 11, 2012 2:21 pm
The knuckles for the tie-rods can wear out and while the TRE's are good, the shaft might not be tight. I have seen this happen on a car I had. Requires either a new knuckle or a very tight nut...
Re: Popping noise.
Postby bmoeller » Wed Jul 11, 2012 4:47 pm
Check the bushing in the steering column too. Grab the shaft behind the rag joint and push-pull on it. That can get plenty sloppy too.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
