Bsmith909 wrote:My truck had a popping noise, until I fixed it earlier today. I replaced the u joints in the driveshaft and all the popping while turning and backing completely stopped. Plus if you haven't changed them recently or don't grease them often it's a cheap fix and would be well worth the time anyway.
Mark Nixon wrote:On a 2wd, check the radius rod bushings.
Mark Nixon wrote:How about upper and lower BUSHINGS? Balljoints?
Sometimes the bolts in the radius rods-to-control arms just creak when you lock to lock it.
