ellis93 wrote:You can use your drums with the 1ton shoes. You just need to have them turned. All you need are shoes and wheel cylinders from a ton truck. I've read that the 3/4 cylinders will work but I can remember where I seen that.
As far as brand, wagner is about the best I've used and I think that Advance carries them.
ahale2772 wrote:my drums are completly shot....they were shot 30kmiles ago..... should i be able to just buy new 1ton drums and shoes and be fine? im probably going to get new wheel cycinders at the same time...is there any advantage to stepping up to 1ton cylinders?
Bob, did you buy the wagner 3inch shoes?
thanks guys
oldestof11 wrote:Get 1 ton shoes, either 3/4 or 1 ton drums for a CUMMINS truck (Gasser 3/4 had a true 2.5" drum from what the parts guy told me), and get new 3/4 ton wheel cylinders. Bigger grabbing force with a slightly smaller bore equals a quick braking force.
ellis93 wrote:Its got to be air causing your problem if the back brakes are adjusted up close. I did the same upgrade and my pedal moves about a 1/2" before you're slowing down.
Mine has been done for awhile and I've not had my rotors warp up from over heating from the rears not having the proper braking force.
I posted about doing this upgrade before I did mine and I believe that Mr BobS said something about another person that had a problem with the rotors warping.
I look at it like this, what's different between the 1ton and 3/4 trucks. The front adapters and the rear shoes and cylinders? Are the masters the same? I've looked at them and I've not seen and diff between the masters, but then again I've not worked on many because they are few and far in between
ahale2772 wrote:hows your ebrake Ironforger? If it feels like its not grabbing the whole way then Ellis is right, your shoes are probably adjusted way out
Ive Got a 1ton Master on my truck and it stops as good as the 3/4 so im guessing there is no bore change there,not definitly sure tho.
I know the front calipers, brackets spindls and all that are different 3/4 vs 1ton
No one seems to want to cut brake dums around here any more, I could do it on my late but I dont have the broing bar bits needed
the parts truck I keep picking parts of of was a 90' 1ton, im starting to consider swapping to a disk d80 if drums are going to cost me and arm and a leg...
