1ton vs 3/4 rear brakes?
Postby ahale2772 » Tue Apr 05, 2011 5:47 am
Im gona rebuild my rear brakes in a few weeks and im wondering if there are anyparts I can upgrade with. I know the front brakes have minor difference between 1ton and 3/4...is it the same out back?
can I use 1ton drums and shoes or are the hubs different? will the backing plates work with 1ton stuff?
what are a good brand of parts to go with? ive had good experience with parts from napa, but i can also get a discount from advance auto on most parts
thanks
Re: 1ton vs 3/4 rear brakes?
Postby ellis93 » Tue Apr 05, 2011 8:17 am
You can use your drums with the 1ton shoes. You just need to have them turned. All you need are shoes and wheel cylinders from a ton truck. I've read that the 3/4 cylinders will work but I can remember where I seen that.
As far as brand, wagner is about the best I've used and I think that Advance carries them.
Postby BobS » Tue Apr 05, 2011 8:47 am
ellis93 wrote:You can use your drums with the 1ton shoes. You just need to have them turned. All you need are shoes and wheel cylinders from a ton truck. I've read that the 3/4 cylinders will work but I can remember where I seen that.
I have over 40K trouble free miles on the 3" rear brake shoes with the original 3/4T wheel cylinders.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby ahale2772 » Tue Apr 05, 2011 9:10 am
my drums are completly shot....they were shot 30kmiles ago :oops: ..... should i be able to just buy new 1ton drums and shoes and be fine? im probably going to get new wheel cycinders at the same time...is there any advantage to stepping up to 1ton cylinders?
Bob, did you buy the wagner 3inch shoes?
thanks guys
Postby BobS » Fri Apr 08, 2011 8:12 am
ahale2772 wrote:my drums are completly shot....they were shot 30kmiles ago :oops: ..... should i be able to just buy new 1ton drums and shoes and be fine? im probably going to get new wheel cycinders at the same time...is there any advantage to stepping up to 1ton cylinders?
thanks guys
I can't find the receipt but I believe they were plain old Carquest's better grade shoes.
BobS
89 D350 Stock
BobS
Postby manyholes » Fri Apr 08, 2011 11:11 am
for what your gonna drop into it for new drums, hardware, shoes. why not look at doing a disc conversion. might be able to find a newer rear with discs to drop in plus pads. i was in a hurry to get mine on the road when i did the brakes or i would of sourced out a disc rear, seen them go for 700-900 around alberta for the dana's cause most stuff is AAM now i think
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Postby ahale2772 » Fri Apr 08, 2011 11:44 am
Yeah that's a good point, wish something just swapped in tho, hard to find a nice HD axle with 3.07s
Postby oldestof11 » Sat Apr 09, 2011 12:53 pm
Get 1 ton shoes, either 3/4 or 1 ton drums for a CUMMINS truck (Gasser 3/4 had a true 2.5" drum from what the parts guy told me), and get new 3/4 ton wheel cylinders. Bigger grabbing force with a slightly smaller bore equals a quick braking force.
Postby Ironforger » Mon Apr 11, 2011 8:32 am
oldestof11 wrote:Get 1 ton shoes, either 3/4 or 1 ton drums for a CUMMINS truck (Gasser 3/4 had a true 2.5" drum from what the parts guy told me), and get new 3/4 ton wheel cylinders. Bigger grabbing force with a slightly smaller bore equals a quick braking force.
I just did the 1 ton upgrade yesterday. Removed the awl accumulator, Cut my existing drums, installed 3" shoes and installed the 1 ton 1 1/8" bore wheel cylinders. My pedal travels way to far before I get braking force. Not road safe. Not completely sure yet, but I'm not ruling out if the larger wheel cyl bore is the culprit. Installed ALL new hardware/springs/adjuster/brake lines etc. I've got the adjusters up tight just touching the drums, but I'm also not ruling out larger inside diameter since I got drums cut because even though I got the starwheels adusted up tight, could it be = more wheel cyl piston travel before shoe to drum contact/brake force? I have a motive power bleeder so I'm doubting it's airbound, but does anyone know if I should bench bleed the master c yl since I had the whole system open & replaced ALL brake lines?
FOR SALE --> 1990 W250 5sp reg cab. 21 mpg. Aprx 145k. (odo broke last year) Fuel screw. KDP killed. Solid floors, rockers & cab corners. Pm me.
FOR SALE --> 1995 Izuzu NPR 16ft Morgan body/side door. 160k. 80 k on reb auto trans. 1 ton lift gate. Pm me.
2002 3500 6 sp Qaud cab 2 wd. 202k <-- One badass truck!
1999 VW beetle tdi. PP520 injec. Rocketchip st. 3. 45 mpg. 260k
Ironforger
Postby ellis93 » Mon Apr 11, 2011 9:08 am
Its got to be air causing your problem if the back brakes are adjusted up close. I did the same upgrade and my pedal moves about a 1/2" before you're slowing down.
Mine has been done for awhile and I've not had my rotors warp up from over heating from the rears not having the proper braking force.
I posted about doing this upgrade before I did mine and I believe that Mr BobS said something about another person that had a problem with the rotors warping.
I look at it like this, what's different between the 1ton and 3/4 trucks. The front adapters and the rear shoes and cylinders? Are the masters the same? I've looked at them and I've not seen and diff between the masters, but then again I've not worked on many because they are few and far in between :roll:
Postby ahale2772 » Mon Apr 11, 2011 9:50 am
hows your ebrake Ironforger? If it feels like its not grabbing the whole way then Ellis is right, your shoes are probably adjusted way out
Ive Got a 1ton Master on my truck and it stops as good as the 3/4 so im guessing there is no bore change there,not definitly sure tho.
I know the front calipers, brackets spindls and all that are different 3/4 vs 1ton
No one seems to want to cut brake dums around here any more, I could do it on my late but I dont have the broing bar bits needed
the parts truck I keep picking parts of of was a 90' 1ton, im starting to consider swapping to a disk d80 if drums are going to cost me and arm and a leg...
Postby BILTIT » Mon Apr 11, 2011 10:12 am
Here are some disc options, not sure if we have the D70 or D70HD?
http://diy4x.com/cart/index.php?route=p ... ry&path=37
Derek B.
BILTIT
Postby ahale2772 » Mon Apr 11, 2011 10:20 am
thanks for the link, but no thatnks LOL, had one of those kits on my 14bolt chevy....after the 12th time that I was under the truck wacking the ebrake screw to release...ill never use those again
Im guessing those use stock hubs? I wonder why they dont use the brackets for the backing plate to secure the disk bracket.
Postby Ironforger » Mon Apr 11, 2011 10:33 am
ellis93 wrote:Its got to be air causing your problem if the back brakes are adjusted up close. I did the same upgrade and my pedal moves about a 1/2" before you're slowing down.
Ellis, did you cut your existing drums? Or did you get new ones?
Ironforger
Postby Ironforger » Mon Apr 11, 2011 10:36 am
ahale2772 wrote:hows your ebrake Ironforger? If it feels like its not grabbing the whole way then Ellis is right, your shoes are probably adjusted way out
E brake seems fine. It seems to grab fairly early. So, I think I see your point - ebrake travel should be a good indicator of how far the shoes are moving before contacting the drum? hence how far do the wheel cyl pistons travel before shoes contact drum? Or wait, update just had a revelation from my old school drum brake days. If I engage the ebrake slightly then attempt to drive, it will prevent the shoes from returning the wheel cyl pistons, so the shoes should be right there - very little piston travel for brake engagement - only as a test to see if piston/shoe travel is my cluprit.
I will report my findings. Thanks for the brainstorming ideas.
Ps, the 1 ton and 3/4 ton do indeed both use the same master c yl.
Ironforger
