4X4 CONVERSION
4X4 CONVERSION
Postby railhor5.9 » Mon Aug 04, 2008 4:16 pm
i wana do a 4wd conversion on my 89 1ton single cab dually... i no i will need a dana 60 but will a ford or gm dana 60 work ? should i box the frame were i mount the hangers and shackles? is the steering box the same? or is the pitman arm in a different spot????? :bh: any imput helps
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby 1991cummins » Mon Aug 04, 2008 6:18 pm
i believe the steering boxes are the same, and i think a dana off of a ford willwork, but i am not sure... the frames are the same and i believe the a-frame unbolts and the shackles bolt on that simple... Maximum altitude in san antonio told me it was the easiest and most strait forward transformation to do... you can even reuse your tansmission with a few alterations.
1991cummins
Postby SChandler » Mon Aug 04, 2008 6:42 pm
The Ford 60 is offset to the wrong side to use it with an original NP205 t-case setup. Since you will be needing to go into the trans to change tailhousings, there are two things you can do: get a Ford t-case and front end and mess with the mounting stuff to get it to bolt to your trans or get a Dodge/Chevy Dana 60 and an NP205 from a Dodge with the same transmission as yours.
SChandler
Postby GO OVRIT » Mon Aug 04, 2008 7:40 pm
The chevy will work, but it is a little different. You'll have to fab up some shock mounts and get a different steering arm. There's a 1/2" difference in center pin to center pin width, but the springs will flex that much. You'll have to redo the brake lines. The steering box will work, but you need to get the 4wd adapter plate and move it up on the frame. The plate is still avilable and the holes are already there. The spring hangers were still available a year and a half ago when I got one last.
GO OVRIT
Postby burnt_servo » Mon Aug 04, 2008 10:52 pm
wouldn't it be easier to find a rotten or body damaged 4x4 and swap the body parts over to the new frame ?
'93 w250 .... stock ...
burnt_servo
Postby GO OVRIT » Tue Aug 05, 2008 2:17 pm
I'd say on these trucks its a toss up. 6 of one 1/2 a dozen of another. It would be easier to find another truck that was 4wd and in good shape. :D
GO OVRIT
Postby 1991cummins » Wed Aug 06, 2008 6:52 pm
i have access to a 1987 3/4 ton 4x4 4spd dodge with a 318... its kind of far... so before i even look at it what are the possibilities...
1991cummins
Postby 1991cummins » Wed Aug 06, 2008 6:54 pm
1991cummins
Postby 1991cummins » Thu Aug 07, 2008 5:53 pm
about what i asked earlier, what i really need to know is if the t-case is the same... and if the cross members are the same...
1991cummins
Postby Richie O » Thu Aug 07, 2008 9:01 pm
the transfer case in the gasser is most likely a aluminum case chain unit like a 208. Diffrent......
Postby 1991cummins » Wed Aug 13, 2008 7:33 pm
ok... so i found a 1992 with high milage... 302000 to be exact... it is a 4wd auto... what is the likely rear end ratio(they dont know and im too far to check)... and are there any differences in the transfer case for autos to manuals???
thanks
1991cummins
Postby KTA » Thu Aug 14, 2008 4:19 pm
Yes the NP205 auto t-case has a smaller input than the manual np205 t-case.
Postby 1991cummins » Thu Aug 14, 2008 4:45 pm
is it just a shaft that smaller... is it economically convertable... or should i just look for another truck?
1991cummins
Postby GO OVRIT » Thu Aug 14, 2008 5:58 pm
Is the 92 a ctd or a gasser? If its a gasser than the t case is deffinately different. Also, if its a gasser 3/4 ton then its got a d44 in the front not a 60. They usually came with 3.54s and sometimes with 4.10s.(gas and diesel)
GO OVRIT
Postby 1991cummins » Thu Aug 14, 2008 6:16 pm
somone on this forum is selling me an entire truck minus engine... 92 4wd 3/4 ton club cab ctd auto with o/d... if the gear ratio is the same what else do i need for the conversion... just the adapter from the auto to the transfer case and a driveshaft to gap the club cab to single cab???
cause that would be great...
1991cummins
