Broken Frame
Broken Frame
Postby Farmboy » Mon Dec 22, 2008 7:06 am
I found out yesterday that the frame where the reese hitch bolts on is split at the bottom corner about 6" :cry: . I was thinking of welding the split and putting a piece of angle iron on the inside and welding it in place. I would have re-drill the holes but I don't know why it wouldn't work. Has anyone ever had this problem? Any other Ideas would be greatly appreciated. :D
Thanks
Farmboy
Postby Philip » Mon Dec 22, 2008 8:33 am
I have seen that problem before.
Angle iron won't fit the radius of the frame very well for a tight fit. A piece of 1/4" steel bent on a brake press will fit better.
Postby Farmboy » Mon Dec 22, 2008 9:51 am
I had thought about grinding the corner off of the angle iron. but maybe there wouldn't be anything left till you get the right radius in there. I think I like your idea better.
Farmboy
Postby Philip » Mon Dec 22, 2008 10:04 am
If they bend it using a die for 3/8" plate the radis would be just about right. :D
Postby randyswelding » Mon Dec 22, 2008 5:38 pm
if your on the cheap,grindin the back off the angle iron will work or if you got a friend with a break that way works too,me id do the angle iron and see if there any way to gusset or box that rear section of the frame and DONT undercut on the weld if you do start all over trust me been there done that(when i didnt know how to weld) :D well good luck
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby Farmboy » Thu Mar 12, 2009 9:02 am
Just thought I would give you guys an update. I tore the bumper and the reese hitch of my truck last weekend and the frame is a little worse than I thought. It is still fixable though. Also the reese hitch is only a class III hitch and is not going to be heavy enough for what I want to do with the truck. So we are going to re-inforce the frame and also build a heavier hitch all at one time and tie the two together. :D
Farmboy
Postby Farmboy » Fri Mar 20, 2009 8:45 am
Got the truck all fixed now! :D fixed the frame and reinforsed the reese hitch. the guy that helped me charged me $75 for his labor and material. Not too bad. just need to wire up my trialer plug and shoot it with some paint :D :D
Farmboy
Postby Richie O » Fri Mar 20, 2009 9:01 am
Thats good. I think I will build my own hitch so it will be strong. I have seen bought hitches fold down pretty easy. I am sure they were overloaded but thats the way I go. :lol:
Postby Farmboy » Fri Mar 20, 2009 12:14 pm
Yeah we beefed up the hitch pretty good. put it this way. If someone rearends me they will definatly know it. :D
crunch crunch 8)
Farmboy
Postby 90FIRSTGEN CUMMINS » Tue Jul 07, 2009 6:06 pm
Along those lines what is the best class 5 hitch to go with. I recently hauled 5 and a half tons of gravel on my flat trailer and when I got it home I noticed the hitch was headed south and winter is not even close. The hitch itself and where the back bolts of the hitch hook to the frame both bent. So i guess what im asking is what hitches have you guys had luck with.
1990 W250 Non I/C, Mostly stock,4 inch Ex,Fuel Screw Turned Up a Little, 727TF, 366 spring, BHAF, Borgeson Steering Shaft, Under-bed B & M transmission cooler, head lights now on relays(just added)
90FIRSTGEN CUMMINS
