need to know what to get
Postby james-93-12valve » Sun Aug 02, 2009 4:30 pm
I Need to know what to get to replace the front suspension on my truck
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
Postby cougar » Mon Aug 03, 2009 7:41 am
It would depend on how far you want to tear it down.
One part that is often overlooked on both 2 and 4 wheel dives is bushings. They do not last 4 ever.
When you do your ball joints, replace your A frame bushings at the same time.
Drag link
Idler
Rod ends
Wheel bearings and seals
Steering coupler
Shocks
Inspect your steering box and especially the mount plate
Check your rims for straightness
Did I miss anything guys?
01 2500 "the work truck".
cougar
