Atlas springs on the way
Re: Atlas springs on the way
Postby RCCUMMINS89 » Mon Mar 17, 2014 10:34 am
Called Atlas this morning.... they are more than apologetic... they knew the 92 and 93 trucks get the 5/8" bolt... someone simply put in the wrong ones.
They are overnighting me the proper bushings. They offered the choice of that, or paying for shipping both ways on the front springs and for them to do it for me.
Postby opiebennett » Mon Mar 17, 2014 4:54 pm
At least they made you feel good about screwing up your order.
Bryan 'Opie' Bennett
91.5 5.9L with 21mm H1C/A518/NP205 Reg Cab LE Pyro/Boost/Trans Temp/BD Fuel Pin/Some fuel screw/Diamond Eye 4" exhaust/B+M Deep Trans Pan/3rd Gen aluminum wheels
opiebennett
Postby RCCUMMINS89 » Mon Mar 17, 2014 5:06 pm
ALL companies make mistakes.... it is what happens after the mistake that matters.
Postby 1992gen1_fan » Thu Mar 20, 2014 6:47 pm
Sounds like they handled it right. :)
1992gen1_fan
Postby RCCUMMINS89 » Thu Mar 20, 2014 7:27 pm
Got the fronts on.... having major problems with getting my rear springs off.
Took it for a quick ride and so far it seems that the front has a tremendous "glide" over bumps to it....EVEN THOUGH, when pushing down on the truck they are RETARDEDLY stiffer than the rear springs. So far, it seems very obvious of the quality difference.
In short..... fronts seem to be absolutely bad Ass!
Postby RCCUMMINS89 » Fri Mar 21, 2014 9:01 pm
In the truck and drove it.........
WOW!!!! Very impressive, and I do need stronger shocks. I need to give them time to settle, because right now my truck is about 3" taller :shock: :shock: (my 37" tires are barely in the fender well).
Has more body roll than before.... but again, I massively need new shocks.
All in all, it is a hugely lifted Cummins Ramcharger (super short wheel base).... so it is firm, YET it is by far the softest Cummins truck that I have ever been in with the exception of my CR... but that was a quad cab.
Postby Sutter1stgen » Fri Mar 21, 2014 9:41 pm
I'm glad this worked out for you. Get some pics up of the stance! I'm dying to see how it sits.
Eric
Sutter1stgen
Postby DMan1198 » Sat Mar 22, 2014 8:46 am
Postby 1992gen1_fan » Sat Mar 22, 2014 2:07 pm
WE NEED PICS! :mrgreen:
1992gen1_fan
Postby RCCUMMINS89 » Sat Mar 22, 2014 2:20 pm
It may be able to happen on Monday. I'm swamped this weekend.
Postby ellis93 » Sat Mar 22, 2014 3:20 pm
RCCUMMINS89 wrote:It may be able to happen on Monday. I'm swamped this weekend.
Too busy for pics? Only thing that could keep me to busy to snap a few pics is sex,no one wants to see that :lol:
I think it as lame excuse :roll:
Postby RCCUMMINS89 » Sat Mar 22, 2014 4:07 pm
Not all of us married folk are in a sexless marriage ;) The good Lord has blessed me in EVERY aspect of life and my marriage.
Postby ellis93 » Sat Mar 22, 2014 5:13 pm
RCCUMMINS89 wrote:Not all of us married folk are in a sexless marriage ;) The good Lord has blessed me in EVERY aspect of life and my marriage.
Wow yo.....I didn't say anything about "less"....I'm busy with that quite frequently :mrgreen:
back on topic,sorry for the troll marks.......this will wither and die then become an Ohio tread for sure. :lol:
Postby RCCUMMINS89 » Mon Mar 24, 2014 10:07 pm
Update.... not sure if I'm just getting used to the ride, or they are getting stiffer... probably a little of both. :? I seem to notice bumps more than I did. But again though, it may be me just getting used to it and forgetting how bad it actually was.
2 things I do know... holy crap do I need shocks... and my f-ing brand new drive line is about to explode. I've already grenaded the slide yoke (up and down movement again after about 250 miles :mad: ) and my u joints are spewing grease out faster than I can put it in. My driveline angle is also ( I fear ) too steep now, due to the 80 pushing everything way the hell forward.
Apparently I have to re invent the wheel..................AGAIN! :x
Postby RCCUMMINS89 » Tue Mar 25, 2014 3:19 pm
Did some pre re inventing today.......
I massively need shocks. After a long conversation on the phone with Atlas, we BOTH feel that the reason it is getting stiffer is because the shocks aren't doing their job. I confirmed this by rocking the vehicle back and forth.... after I counted to 5 rolls I :roll: and realized things don't work right unless all supporting parts are in working order.
As far as driveline angles... I am pulling out the rear t-case yoke bearing and replacing it. I found that it is massively worn out and I can literally hear the yoke moving up and down. Only imagine what it does under torque. I feel that is why I'm getting the vibration and why it is tearing out my shaft/joints so quickly.
