In the truck and drove it.........
WOW!!!! Very impressive, and I do need stronger shocks. I need to give them time to settle, because right now my truck is about 3" taller
(my 37" tires are barely in the fender well).
Has more body roll than before.... but again, I massively need new shocks.
All in all, it is a hugely lifted Cummins Ramcharger (super short wheel base).... so it is firm, YET it is by far the softest Cummins truck that I have ever been in with the exception of my CR... but that was a quad cab.
89 RC on shortened 92 diesel frame - NV4500 w/dual disc/4.10s on 37s. - Self built pump, "hot screw", lots of timing, True high volume low pressure lift pump, 62fmw/68/.7gated, 77lpm SAC Inj., Studs/O-rings,- 423/1220 Mustang - 11/16/2013
http://www.TheHungryDiesel.com full line dealer, if you don't see it please ask.
