rear axle
Postby Philip » Sun Mar 02, 2008 7:50 pm
Michael I forgot to add the allison TCM has an input for the low range signal. That is why I am not to worried about it. I can use the 4x4 indicator circuit from the 205 linkage.
The main imput I have to figue out is the output shaft speed. That 119 tooth ABS ring is 3 teeth short of the number I need. But I don't think it is that much of a problem. I'll be sending a PM to a guy on TDR soon and confirming it.
Postby dpuckett » Fri Mar 07, 2008 4:43 pm
Philip- I counted the teeth in my 92 W350 carrier, and came up with 120 in both directions.
DP
