Wide/drag tires for D250
Postby Broncdiesel » Fri Apr 08, 2011 10:42 am
Searched can't find much on wide tires for the rear of a D250. I need something with some tread life and the M&H tire is beyond what I need. Also, does anyone run 10" wheels with around 5" of backspacing on the rear? Thanks for replies
Broncdiesel
Re: Wide/drag tires for D250
Postby manyholes » Fri Apr 08, 2011 11:05 am
are you looking for a D.O.T. aproved slick?? radial i take it???whats overall size that your looking for??
1990 W250 dodge ex cab, LB, work in progress. truck was originally reg cab/lb, ex cab is an add on.fuel pin turned, 30psi, bhaf, straight piped 3", new rear springs with shackle flip, 4" lift front, crossover steering, waiting on piston lp, c/c s/b conversion, turbo upgrade and intercooler install
manyholes
Postby Broncdiesel » Fri Apr 08, 2011 6:46 pm
I want a little more life from the tire then a dot slick. I have been looking at the bfg radial t/a, the load range is my issue. I am agreeable on size...Mybe a 295/50-16
Broncdiesel
Postby SNOOT » Fri Apr 08, 2011 9:41 pm
50 series you may run out on your top end pretty fast....
1993 W350
SNOOT
Postby oldestof11 » Sat Apr 09, 2011 1:09 pm
Get an 8" wide, 18" tall wheels like Eagle Alloys 050 series wheel http://www.arrowheadtiredemo.com/Eagle- ... d=10878838
And throw some Nitto Dune Grapplers on it http://www.discounttirezone.com/NITTO-D ... -3487.html
And you have yourself a 29" tall tire that is wide and fits our trucks.
Postby Remps » Sun Apr 10, 2011 7:20 am
I have Mickey Thompson baja MTZ 305 70 16's (90% worn) mounted on stock rims on the back of the 90. (I know,I know, too big for the stock width rims.Found em at the garbage dump and mounted them myself) Aired down to 30 psi, they hook suprisingly well with about 10" tread width. Load range D, good for 2910 lbs, 50 psi max pressure. Height is about 31".
Postby Broncdiesel » Mon Apr 11, 2011 5:58 pm
I like those wheels! I wanted to stay with a 16" wheel for a vintage look, the tires are just not available. I guess bigger rims are the only way to go. Thanks for the replies!
Broncdiesel
Postby SNOOT » Mon Apr 11, 2011 8:21 pm
Broncdiesel what year truck do you have?
1993 W350
SNOOT
Postby Broncdiesel » Fri Apr 15, 2011 6:35 pm
Sorry I didn't reply sooner its a 89 d250 auto.
Broncdiesel
