Steering Shaft
Steering Shaft
Postby sb91ctd » Thu Dec 29, 2011 4:40 pm
Anyone have the problem on your steering shaft right before it goes into the box, a small shaft going into a larger shaft, i have a ton of play here and i believe that is the main cause of the hellacious shake around 40, front tires are shot and i know that it plays a roll as well. Anywho who else has encountered this and what course of action did you take?
Steve
1991 W250, stock for the moment, 146,xxx , 727 with transgo shift kit, non i/c, currently being assymbled
1988 super10 4cyl 5sp
sb91ctd
Re: Steering Shaft
Postby LuzRD » Mon Jan 02, 2012 4:41 pm
Sounds like you need to rebuild your slip joint. Its a common issue, I do mine almost annually. The parts are dealer only but only run about $30-40.
There are alternatives which involve replacing the entire steering shaft from the box to the column. I'm ordering a borgeson hd replacement shaft tomorrow (000943= double u joint hd shaft that eliminates the slip joint and rag joint. 000940= single u joint shaft that retains the factory rag joint but eliminates the slip joint) they run around $180-200. Which is only a little more than what I have into slip joint rebuild parts to date
LuzRD
Re: Steering Shaft
Postby oldestof11 » Mon Jan 02, 2012 6:48 pm
You can get the rebuild for the slip joint at Autozone...
Re: Steering Shaft
Postby LuzRD » Mon Jan 02, 2012 8:19 pm
Lemme guess... For about half the dealer price? Figures, I was told it was dealer only by the parts store I usually use
To the op, dont forget to inspect the rag joint to if your rebuilding the stocker. the rebuild is pretty darn easy, and I hear that some guys drill and trap for a grease fitting while its all apart so they can grease it regularly
LuzRD
Re: Steering Shaft
Postby Hansen01 » Tue Jan 03, 2012 8:52 am
on mine the housing is wore out. can we still get those??
Under construction...
Hansen01
Re: Steering Shaft
Postby oldestof11 » Tue Jan 03, 2012 4:17 pm
Try 1/3 the price. $11.xx Since I can now order McMaster Carr stuff through work at a discount, I am going to measure the shaft and buy a Ujoint for $40-$50.
Re: Steering Shaft
Postby blakemartz12 » Thu Jan 31, 2013 12:21 am
Any part numbers? I noticed the same problem tonight on my 92. I'm sure I can find it (I do work at a parts house) but if you already looked it up that would be easier. Thanks
blakemartz12
Re: Steering Shaft
Postby Hansen01 » Thu Jan 31, 2013 6:52 am
Part # 425-252
Line: DOR
$48.00 from O'Reillys
Thats for the housing of the joint
Hansen01
Re: Steering Shaft
Postby jderr664 » Thu Jan 31, 2013 10:55 pm
That is good to know info. I thought that piece would never be produced again!
jderr664
Re: Steering Shaft
Postby NJDodge » Sun Feb 03, 2013 12:06 am
Wait, what play do you mean? I don't have much play side to side, but up and down is pretty sloppy. Turning side to side in niltch though. Also my truck is lifted 4 inches.
1990 Dodge W250- 360 V8, 35x12.5x16.5 BFG, 4" rough country lift, NP205 transfer case, 727 trans.
NJDodge
